Thread: :: Solved:: Tick but Not Knock
Results 41 to 60 of 67
  1. #41
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Yeah I'd love a cam just don't have the cash to do it the way I want too... well I guess it just depends on how much I pay for the donor.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #42 Re: :: Solved:: Tick but Not Knock
    Yet you have a $500 phone? LOL
    Oct 2011
    MI
    It's just bad timing.. I've got my fiancee watching my spending... last motor I built I spent a bit much and she's on top of it this time.. and for the record the phone cost 199 lol
    Sucks the here about the chipped pistons hopefully youll find a reasonable donor. You could always sell the lifters and make some monry back...hell i could use them depending on price. car-parts.com to search for local junkyards
    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
    04 Comp G.
    Oct 2011
    MI
    I'm not having much luck finding a motor around here.
    Oct 2011
    MI
    It'd be nice to just find 2 pistons and replace them but I'm not sure what all I'll have to have to remove and reinstall the new.
  7. #47 Re: :: Solved:: Tick but Not Knock
    most of the time a partial rebuild wont hold up.
    same have done it, most have failed.
    and you would still need to pull the engine, and then the pan, unbolt the rods from the crank, push the piston up and out, then put the new ones in. and then pray it lasts.
    Or measure everything and make sure its in spec.
    Engine fails because something is out of spec, unless you fix that, 50 mile wonder.
  9. #49 Re: :: Solved:: Tick but Not Knock
    with just chipped piston, i would think if you check and recheck all your bearing clreances you may have a chance, being that no bearings spun.
    plastigauge will be your new friend for sure.
    Oct 2011
    MI
    Cyl 2 is scratched up. It's getting pulled tonight. I found a motor I'm going to get in the morning should be on the road by Monday for work.
    Oct 2011
    MI
    Nice door stop...
  12. #52 Re: :: Solved:: Tick but Not Knock
    man you waste no time
    Oct 2011
    MI
    Lol nope. I'll grab the motor tomorrow morning.. then head into work.. have it finished by Sunday easily. I just decided to put all the stuff I got for the previous motor on the new motor as well... not sure if I'd ever notice the difference with ls7 lifters but hey at least they are new.
    Oct 2011
    MI
    Donor is home
    Oct 2011
    MI
    From earlier...
  16. #56 Re: :: Solved:: Tick but Not Knock
    whats the donor story, car and miles?
    looks good so far. you certainly want your car back on the road fast lol
    Oct 2011
    MI
    Lol yeah Im taking my time really .. ill have it ready for work on Monday (knock on wood)
    Donor car was a 2004 White CompG that was smacked in the rear. 98,180 miles. It already had LIM done but I put a new one on anyways the nIce thIck alum. Gm gaskets..Oil pan, sc, and valve covers as well. I cleaned it up... sanded and painted a few items with high temp paint the final shot should be a nice clean look.
    I now have an extra set of heads, an intake manifold, injectors,ps pump, and genV sc
  18. #58 Re: :: Solved:: Tick but Not Knock
    Thats easily a couple hundred dollars worth of spare parts you got there.
  19. #59 Re: :: Solved:: Tick but Not Knock
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    be a cool dude.. let me have the genv before somebody dibs it
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  20. #60 Re: :: Solved:: Tick but Not Knock
    i thought you sold?
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. Lifter tick?
    By My GTP 97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 01:03 PM
  3. Top end tick?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:42 AM
  4. Tick Tick Tick
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2009, 11:42 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
