Thread: Valve cover removal
Page 1 of 3 123 LastLast
Results 1 to 20 of 59
  1. #1 Valve cover removal
    Slower, Lower Delaware
    I've tried looking but can't find any info on what has to come off to remove the valve covers. Could someone point me in the right direction.
  2. #2 Re: Valve cover removal
    Cambridge, Ontario Canada
    google. grand prix lim gaskets 33 mins - watch that. It might be in the how to section as well
    2005 E55 - stock
  3. #3 Re: Valve cover removal
    For the front one...should just need to remove misc. plugs that might be in the way and the coil pack bracket needs to come off. Unplug it or the battery though.
    I'd unplug the battery because you'll be yanking off the alternator and the MAP bracket/engine pull brackets to get to the rear one.
    Bolts in the VC are 3/8" SAE and don't require more than 12~ ft.lbs. when re-installing.
  4. #4 Re: Valve cover removal
    Uh..they are 87 inch lbs of torque.
  5. #5 Re: Valve cover removal
    7.25 ft. lbs.
    Doesn't matter really.
    Squish the grommets.
    It's a 3800, it'll work.
  6. #6 Re: Valve cover removal
    Thanks for all the replys. I scanned some more and found some info. I should be OK. Any advice on the coolant elbows? I hear they can be pulled loose when removing brackets but don't have to be.
  7. #7 Re: Valve cover removal
    I had enough clearance to remove the rear VC without pulling the elbow out. Most people say you can't but don't listen to them
  8. #8 Re: Valve cover removal
    your alt bracket lays on the valve cover, so loosen up all 3 bolts just a little bit and you should be ok, or just change them as your right there.
    dorman came out with a metal elbows now.
  9. #9 Re: Valve cover removal
    Denver
    If you don't already have the new metal LIM gasket, just do them both.
  10. #10 Re: Valve cover removal
    Is there much to changing the elbows. I haven't even seen them. I plan an IC for next spring, almost enough money put away. I have an account I'm putting $40 a week into.
  11. #11 Re: Valve cover removal
    the elbows are easy. easier then the valve cover gasket on the rear, thats for sure lol
  12. #12 Re: Valve cover removal
    ^^Troof.
  13. #13 Re: Valve cover removal
    Things get ugly if you snap the VC bolts in the head by overtorquing. The thing for people reading this to keep in mind is that Blue, myself and bunch of the normal posters here have done this stuff so much, it's a matter of habit. Blue says squish the grommets, and what he means is.. the bolts have a sleeve on them that limits movement. Once the bolt is bottomed out. and snugged down. you are all set. If you try and be a muscle man, you'll either strip the bolt or break it.
  14. #14 Re: Valve cover removal
    Thanks, good information. I've worked on a LOT of cars but this is my first time on a 3800. It's those particular litlle tips that make a big difference.
  15. #15 Re: Valve cover removal
    Omaha, NE
    I've found it is easiest to remove the valve covers and change spark plugs with the engine out of the car.
  16. #16 Re: Valve cover removal
    I've done the plugs and wires. Hey, there's some cars out there that you change some of the plugs from inside the car.
  17. #17 Re: Valve cover removal
    Omaha, NE
    Quote Originally Posted by Sudden View Post
    That's true, I had to do it to a Nissan Leaf once.
  18. #18 Re: Valve cover removal
    What about those Cummins plugs?
  19. #19 Re: Valve cover removal
    I was thinking more like a Sunbeam tiger.
  20. #20 Re: Valve cover removal
    Can't find a compression check hose to blowup my cylinders.
  1. Rear valve cover removal
    By Angleiron in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-02-2012, 11:58 AM
  2. EGR valve cleaning and removal
    By JAXSON in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2010, 12:09 AM
  3. Front Valve Cover Removal
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-26-2008, 05:52 PM
  4. Rear Valve Cover Removal
    Last Post: 08-24-2008, 12:46 PM
  5. Valve Cover Removal
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 07:19 PM
