Thread: P0171 after installing headers
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: P0171 after installing headers
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Thanks Tony, I'll give that a try and let you know what I come up with.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #22 Re: P0171 after installing headers
    Knoxville, TN
    Well, the connector was sending it the correct voltages, however, the current to/from the circuit was much lower than expected. When I pulled the sensor out, it was covered in black soot. I cleaned the soot off with some carb cleaner, and after re installing the sensor, I got a p0134 code. "Sensor no activity". Ideas?
  3. #23 Re: P0171 after installing headers
    Did you plug it back in?
  4. #24 Re: P0171 after installing headers
    Knoxville, TN
    Of course, it's still currently plugged in. I also checked the #21 fuse under the hood, looks perfectly fine, swapped it with another 15A fuse just in case. Still the same problem.
  5. #25 Re: P0171 after installing headers
    Run the wiring and look for any bare spots. Might have to end up replacing the sensor.
  6. #26 Re: P0171 after installing headers
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    You killed the sensor. I know some have cleaned O2 sensors and have had luck but those are few and far between. There is really no effective way to clean the sensor. I could go into alot of technical mumbo jumbo on O2 sensors but I'll keep it simple: Ya killed it if the circuits and connections are good.
  7. #27 Re: P0171 after installing headers
    Aug 2012
    Somerset WI
    The black soot on the sensor....I would be curious as to why that is. Check into that as its not normal. Keep us posted
  8. #28 Re: P0171 after installing headers
    Black means rich. Can be normal if he's been running it for short periods trying to fix something.
  9. #29 Re: P0171 after installing headers
    Knoxville, TN
    This is what I'm thinking. This dumb thing has given me 3 different codes since moving it into my headers. I'll look again for damaged wiring first, though.
    As far as "killing the sensor". I doubt carb cleaner killed a sensor that can survive 500 degree heat. I'd imagine I damaged it when I used a propane torch on the manifold while forcing it to unscrew. Possibly that's the root of my problems.
  10. #30 Re: P0171 after installing headers
    Aug 2012
    florida
    I HAD THAT CODE TOO HAD VACUUM LEAK BEHIND MASTER CLY THE FRONT BRAKE BOOSTER SEAL WAS TORN REPLACE SEAL TOOK CABLE OFF BATT IT WENT AWAY.CODE PO 171 VACUUM LINE ,MAF PO 171 SYSTEM TOO LEAN (BANK 1). HAD BOOSTER TROUBLE REPLACE SEAL BOOSTER OK DID NOT HAVE TO REPACE BOOSTER WAS VACUUM LEAK BRAKE BOOSTER FRONT SEAL HAD TO PICK UP AT JUNK YARD NO ONE HAD IT IN AUTO STORE OR DEALER CHECK OBD-II Trouble Codes - DTC Codes Car Repair
  11. #31 Re: P0171 after installing headers
    Knoxville, TN
    FIXED! Installed new Denso O2 sensor, no more codes, no more problems. Runs great. Thanks for the troubleshooting steps guys, this time the fix wasn't the most probable one.
  1. Headers installing problem...
    By szalajka05 in forum General Tech Discussion
    Last Post: 04-07-2012, 12:02 PM
  2. 00 Gtp problems after installing sd headers
    By 3CLiPSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 03:05 PM
  3. installing headers and...
    By c4gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2011, 04:58 PM
  4. Installing Headers?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 01-02-2011, 05:22 AM
  5. Installing Headers
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2009, 02:25 PM
