I don't know what a 131 is off the top of my head. Sorry, would you mind at least listing the name of the code. Maybe a link to GearChatter or something with the FSM info to read up on.
As for the gramatics, it was early and yeah..it made sense in my head. What I tried saying is. It is funny to me, that I pulled the cable possibility out of thin air. You hadn't mentioned removing the cables or anything of that nature. Somehow, I knew.
http://www.obd-codes.com/p0131
"P0131 OBD-II Trouble Code
Technical Description
Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 1)
What does that mean?
Essentially the same as P0136 and P0137, a P0131 code refers to the first oxygen sensor on Bank 1. P0131 means the O2 oxygen sensor's voltage remained low for longer than 2 minutes. This, is interpreted by the ECM as a low voltage condition and sets the MIL. Bank 1 Sensor 1 is located in front of the catalytic converter."
