Thread: installing headers and...
Results 1 to 20 of 21
  1. #1 installing headers and...
    Nov 2011
    Northern MN
    I am putting headers on my 01 gtp this friday i hope, but my problem is my converter needs to be removed/moved. what do i do to get the rear o2 sensor to not set a check engine light? can i just move everything back a foot? i read that the o2 emulator does not work on 01+ is this correct? Thanks in advance!
  2. #2 Re: installing headers and...
    Oct 2011
    Toledo, OH
    Yes you can move it back a foot, but will need a harness extender. Or cut the wires and lengthen them yourself.
    7"
  3. #3 Re: installing headers and...
    Nov 2011
    Northern MN
    ok all i needed to know thank you much!
  4. #4 Re: installing headers and...
    Grand Rapids, MI
    well you could get a tune and drop your pulley size (pulley isn't necessary, just a nice upgrade) and then remove that code during the tune. that's what i did. i'm running catless with headers and don't have an engine light one.
  5. #5 Re: installing headers and...
    Nov 2011
    Northern MN
    Quote Originally Posted by brandonl2000 View Post
    New question. The s/c I put on this motor has a smaller pulley on it then stock. Reason for buying the headers. Car has ubend and res delete on it and I have zero kr. Problem is I have no idea what pulley it is. No stamps or marks of any sort that i could see. It's a press on. How do I measure to figure out what it is? Thanks.
  6. #6 Re: installing headers and...
    utah
    cats are for commies
  7. #7 Re: installing headers and...
    Quote Originally Posted by boostedcompg View Post
    and homeless people.
    and hippies.
    two different cats.
    Same outcome: Get rid of them.
  8. #8 Re: installing headers and...
    Grand Rapids, MI
    wow what dumb ass did that??
    but you can break out your tape measure and measure the diameter. or if that's difficult because of the bolt you may have in the center, you can measure the radius (only half of it) multiply by two and find it that way.
  9. #9 Re: installing headers and...
    Nov 2011
    Northern MN
    Ok didn't know if that was right. If I remember right it was 3 3/4ths. I could be wrong don't have the car here with me.
  10. #10 Re: installing headers and...
    Grand Rapids, MI
    are you sure it's a non-stock pulley? stock=3.8".
  11. #11 Re: installing headers and...
    Out West
    3 and 3/4th = 3.8 brandon..
    Whine with your Cheese?
  12. #12 Re: installing headers and...
    Grand Rapids, MI
    Quote Originally Posted by Nixon View Post
    that would be the point i'm making, genius.
    3 3/4=3.75 which is roughly 3.8 given it's measured with a tape measure.
  13. #13 Re: installing headers and...
    Out West
    Don't sass at me boy.
  14. #14 Re: installing headers and...
    Nov 2011
    Northern MN
    It's way smaller then the other pulley on my spare charger. I will remeasure when my wife gets here. And that's the outside rib if that is correct? Not where the belt rides. I just measured the one at my shop and it a 3.8 on the groves so I will measure the other in a bit. Thanks for your help I really appreciate it.
  15. #15 Re: installing headers and...
    Out West
    Cool deal.
  16. #16 Re: installing headers and...
    Grand Rapids, MI
    Whaaaaaaat you gunna do about it!?!?!?!
  17. #17 Re: installing headers and...
    Nov 2011
    Northern MN
    3.5 pulley
    Thanks again.
  18. #18 Re: installing headers and...
    Out West
    It's a 3.5? I didn't even know they made 3.5's in press on.
    You want to at least get some headers and check out getting an overkill tune if not a custom tune from a local.
  19. #19 Re: installing headers and...
    Nov 2011
    Northern MN
    Got headers. Tune will have to wait. Not sure if there is even anyone around my area that tunes 3.8s. Like I said zero kr tho is weird.
  20. #20 Re: installing headers and...
    Out West
    Just a question...but how hot does your motor get?
    If below 160 on a stock tune you will NOT show KR.
  1. installing pace setter headers
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2011, 11:26 PM
  2. Installing Headers?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 01-02-2011, 05:22 AM
  3. Installing Headers
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2009, 02:25 PM
  4. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
  5. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
