Thread: supercharger noise?
Results 1 to 20 of 22
  1. #1 Re: supercharger noise?
    Owen...Describing has nothing to do with being new. Do your best to be as descriptive as possible. If you don't understand what we are saying when we mention you gave us little to use. Take a look at your first post. When I read it (and I have ESP usually) what I see is you saying. "I hear a noise, my SC oil was changed, could it be the SC?".
    My thoughts on that are, sure it can be. However knowing more, like your second post. "Sounds like a belt rubbing, there is a lot of belt wear". That gives us much more info to go on. You noted the wear and sound of a belt wearing. My questions to further the info are:
    How is the belt wearing?
    Only on one edge?
    The wriiting has worn off?
    The ribs are cracked?
    Have you heard of the screwdriver etc trick to listen to things, or do you have a mechanics stethescope (cheap tool, super useful). Those would allow you to listen to various things and have a good idea of what may be bad.
  2. #2 Re: supercharger noise?
    May 2012
    Only on one edge?
    first off, thank you for helping me on this problem
    yes the belt is only wearing on one side the grooves are perfectly intact
    no cracks. i havent done much diagnosing because i would have thought this was
    going to be an easy fix. ill get more information and ill have it posted by tomorrow along with video and pictures
    thanks for the help its greatly appreciated!
  1. Help with Supercharger Noise
    By MidnightBlue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2012, 11:52 AM
  2. Supercharger noise?
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2012, 09:29 PM
  3. noise from supercharger
    By 02bluegtss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2011, 12:04 PM
  4. noise from supercharger
    By johndoe35652 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 02:22 AM
  5. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
