Thread: Engine Reassembly Help.. L67 lots of pics
Results 1 to 20 of 54
  1. #1 Re: Engine Reassembly Help.. L67 lots of pics
    Apr 2009
    Fort Worth TX
    The work on the head should be OK but if you can see any really jagged metal in that chip I would get a really small grinding bit for the Dremel and smooth it out. It's the exposed casting grain that will cause detonation. Under hard acceleration a little glowing ember will fire that cylinder off early. People polish the combustion chambers for the very same reason. The smoother the less chance of pre-combustion.
  2. #2 Re: Engine Reassembly Help.. L67 lots of pics
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Quote Originally Posted by Rico View Post
    i think i got it all down compared to the sharp edges it had and really cleaned them up pretty good especially the block.
  1. 04 GTP - Transmission build started!!
    By ADrugDealer in forum Members Rides
    Last Post: 06-05-2015, 11:34 PM
  2. New Pictures (LOTS OF PICS)
    By Fivefingerdeathpunch in forum Off Topic Discussion
    Last Post: 08-11-2010, 09:29 PM
  3. Wheels on/Sd air dam on!! lots of pics
    By glanzergtx in forum Tires & Wheels
    Last Post: 05-02-2009, 01:01 AM
  4. Where my $$ has gone..lots of pics
    By TJs97 in forum Visual/Body Modifications
    Last Post: 03-10-2009, 09:32 PM
  5. Lots of pics of my stock GTP
    By rfmgtp02 in forum Visual/Body Modifications
    Last Post: 11-06-2008, 10:45 PM
