Thread: Engine Reassembly Help.. L67 lots of pics
Results 21 to 40 of 54
  1. #21 Re: Engine Reassembly Help.. L67 lots of pics
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    What can I do about this and take it off safely?
  2. #22 Re: Engine Reassembly Help.. L67 lots of pics
    Apr 2009
    Fort Worth TX
    2000 grit sand paper with 30 weight motor oil.
    Do it with the cylinder horizontal so nothing ends up between the piston and cylinder wall.
    Wipe it dry with a clean paper towel then apply a thin coat of clean motor oil.
  3. #23 Re: Engine Reassembly Help.. L67 lots of pics
    Apr 2009
    Fort Worth TX
    BTW
    Did you paint the supercharger sealing surface of the LIM?
    If you did I would take that off of there.
  4. #24 Re: Engine Reassembly Help.. L67 lots of pics
    Honiing stone or maybe a buff with steel wool/green scrubby. I once took a cam to a machine shop to have it polished and the owner explained that basically they would use a green scrubby and some oil, lightly rub. That's a basic polish to get surface rust off. It worked great for me.
    From
    To
  5. #25 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    Quote Originally Posted by Rico View Post
    I have super fine steel wool the finest I could get it is 0000 idk if u know what I mean by that.
    Can I use that and some motor oil with it on block?
    Will be doing it today If all is good with that..
  6. #26 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    From
    To
    Now that's sweet I will give it a quick try right now with some motor oil and a very fine steel wool hope it works fine need to put this together
  7. #27 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    What do you think good enough?
    I cleaned off the surface rust and that **** worked great especially with the motor oil thanks guys
  8. #28 Re: Engine Reassembly Help.. L67 lots of pics
    Apr 2009
    Fort Worth TX
    The work on the head should be OK but if you can see any really jagged metal in that chip I would get a really small grinding bit for the Dremel and smooth it out. It's the exposed casting grain that will cause detonation. Under hard acceleration a little glowing ember will fire that cylinder off early. People polish the combustion chambers for the very same reason. The smoother the less chance of pre-combustion.
  9. #29 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    i think i got it all down compared to the sharp edges it had and really cleaned them up pretty good especially the block.
  10. #30 Re: Engine Reassembly Help.. L67 lots of pics
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    FYI your head is cracked between the intake and exhaust seats. on your pic, it would be the left cylinder, think i saw one on the middle cylinder as well. my heads were cracked in the same place.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  11. #31 Re: Engine Reassembly Help.. L67 lots of pics
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by TEK310 View Post
    Do you mean in the red circle?
  12. #32 Re: Engine Reassembly Help.. L67 lots of pics
    Mar 2012
    Dallas
    correct
  13. #33 Re: Engine Reassembly Help.. L67 lots of pics
    my heads are cracked in about four out of six cylinders.
    Some of them go about 0.250"+ back too.
    Go team 3800.
  14. #34 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    Ok so i finally cleaned up the heads and block i just have to take one bolt out of the head since it is blocked by a manifold bolt and doesnt let me take it out.
    But is there a way in wich we shoud torque the bolts? meaning the top bolts first or bottom ones?
  15. #35 Re: Engine Reassembly Help.. L67 lots of pics
    There is a torque sequence/pattern. should be in the box with the new head bolts.
  16. #36 Re: Engine Reassembly Help.. L67 lots of pics
    Apr 2009
    Fort Worth TX
    Working length wise start at one of the 4 center bolts and work your way to the edge diagonally across center then across.
    Then go across centerdiagonally
    Then go across
    7 1 3 5
    8 4 2 6
  17. #37 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    Then go across
    7 1 3 5
    8 4 2 6
    Thanks the numbering helps lol
    hopefully by this week i can put the head on and torqued i just need to get that darn head bolt out
  18. #38 Re: Engine Reassembly Help.. L67 lots of pics
    The hex on the end of the exhaust stud holding you up is a 5.5mm. If it's rusty or you strip the hex, put one of the exhaust nuts on it backwards, then put a nut on forwards and using two wrenches, lock them together. That should allow you to take it off.
  19. #39 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    Thanks never would of thought of that i think that would much easier to do i shall give it a try
  20. #40 Re: Engine Reassembly Help.. L67 lots of pics
    Buena Park Ca
    what do you guys think clean enough? safe to mount the heads on?
  1. 04 GTP - Transmission build started!!
    By ADrugDealer in forum Members Rides
    Last Post: 06-05-2015, 11:34 PM
  2. New Pictures (LOTS OF PICS)
    By Fivefingerdeathpunch in forum Off Topic Discussion
    Last Post: 08-11-2010, 09:29 PM
  3. Wheels on/Sd air dam on!! lots of pics
    By glanzergtx in forum Tires & Wheels
    Last Post: 05-02-2009, 01:01 AM
  4. Where my $$ has gone..lots of pics
    By TJs97 in forum Visual/Body Modifications
    Last Post: 03-10-2009, 09:32 PM
  5. Lots of pics of my stock GTP
    By rfmgtp02 in forum Visual/Body Modifications
    Last Post: 11-06-2008, 10:45 PM
