Quote Originally Posted by Rico View Post
2000 grit sand paper with 30 weight motor oil.
Do it with the cylinder horizontal so nothing ends up between the piston and cylinder wall.
Wipe it dry with a clean paper towel then apply a thin coat of clean motor oil.
I have super fine steel wool the finest I could get it is 0000 idk if u know what I mean by that.
Can I use that and some motor oil with it on block?
Will be doing it today If all is good with that..
