Thread: Coolant Resorvoir Relocation.
Results 1 to 10 of 10
  1. #1 Coolant Resorvoir Relocation.
    May 2012
    Burlington, Wisconsin
    So I drive a 98 GTP, but 99 was the year the coolant resorvoir was relocated making intakes more efficient. I'm buying a new resorvoir and relocating it to the same place it is in a 99. My question: should I just buy the resorvoir and bolts to mount it, or more? Will I need new hoses so they will reach the new location? New coolant hose seals? Or will my current ones work with the relocation? Oodles of thanks to the person who can answer this for me .
    EDIT: I'm also doing new coolant elbows and a 180* t-stat when I do this. Coolant is also being flushed.
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  2. #2 Re: Coolant Resorvoir Relocation.
    Feb 2010
    TN
    when I hoked up mine the hoses reached no problem
  3. #3 Re: Coolant Resorvoir Relocation.
    May 2012
    Quote Originally Posted by Logan541 View Post
    Alright, great. So just the 99 coolant resorvoir was needed?
  4. #4 Re: Coolant Resorvoir Relocation.
    Feb 2010
    TN
    Quote Originally Posted by Btownmills View Post
    yep
  5. #5 Re: Coolant Resorvoir Relocation.
    Jan 2012
    Philadelphia
    the 97-98 ones look better
  6. #6 Re: Coolant Resorvoir Relocation.
    May 2012
    Quote Originally Posted by gtpeddie View Post
    I need a new spot so it isn't so close to the intake though ;p.
  7. #7 Re: Coolant Resorvoir Relocation.
    Jan 2012
    Philadelphia
    ah i see i dont have that problem i have ram air
  8. #8 Re: Coolant Resorvoir Relocation.
    May 2012
    You're a lucky bastard and this is the cost effective way for me to do it ;p.
  9. #9 Re: Coolant Resorvoir Relocation.
    I just set mine up on the strut tower and got my drill out and drilled 2 holes and bolted it up I had to cut my overflow line since it was to long.
  10. #10 Re: Coolant Resorvoir Relocation.
    Best ecomonic way to do it. Hit a JY, get the bottle, hose and the little white piece that the bottom of the bottle sits on. They charge you peanuts for the bottle and you smile. Then put the white thing on your car, hold the bottle in place at the top and drill your two holes for bolts.
  1. Alternator relocation bracket
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 05:43 PM
  2. SD headers o2- relocation
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2011, 01:33 PM
  3. computer relocation mount by zzp
    By christopher8911 in forum General Tech Discussion
    Last Post: 07-19-2010, 11:44 AM
  4. Intense Oil Filter Relocation Kit
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2008, 01:36 PM
