Thread: MAF problems on GTP
Results 1 to 8 of 8
  1. #1 MAF problems on GTP
    Apr 2012
    Mattawan, MI
    I have a GTP. My MAF sensor went out recently, i took it out and sprayed the MAF cleaner on it. It didnt work so i decided to get a new one. After installing, it still didnt work. I checked the fuses and it was blown. I took it to zzp and they said that the O2 sensor wiring was burnt because it was rested on my headers. during this time i am getting horrible Gas mileage. (10MPG). I took the o2 out and redid the wiring, it runs much better and is getting alot better gas mileage 20+. But the MAF Code still pops up and the car does not run right at WOT. Should i return the MAF and get a new one or......thanks!
  2. #2 Re: MAF problems on GTP
    Yes.
  3. #3 Re: MAF problems on GTP
    also check the wires to the maf plug, they get heated up and the insulation cracks, bad wires, same code as a bad maf.
  4. #4 Re: MAF problems on GTP
    Apr 2012
    Mattawan, MI
    I checked both of the MAF fuses to and they are both not blown so i believe it is the MAF
  5. #5 Re: MAF problems on GTP
    Apr 2012
    Mattawan, MI
    I Just went to autozone and exhanged my old MAF with a new one, the code is still up. It also reads a turbine sensor, and a crackshaft sensor.
  6. #6 Re: MAF problems on GTP
    post the codes your getting.
  7. #7 Re: MAF problems on GTP
    Apr 2012
    Mattawan, MI
    p0102, po336, p1676, and thats it. turbine one went away.
  8. #8 Re: MAF problems on GTP
    so a maf, the crank and the EVAP.
    the crank sensor, start wrenching and change it. heres the how to. http://www.grandprixforums.net/crank...ent-2-698.html
    the maf re check the wires to the plug, bend it back at the plug, to see if the wires are showing at all where they should be sealed off.
    if you have cracks the wires gets whats known as dry wire, the wire becomes dark brown, not shinny copper any more, and no longer passes current correctly, and throws the code for the maf.
    the EVAP, i dont have any experience fixing. but it could be as simple as a gas cap from what i've read here.
  1. Problems
    By BThomp in forum Introductions/Noob Questions
    Last Post: 08-22-2010, 05:54 AM
  2. DIC problems!!!!! HELP!!!!
    By putskijr in forum General Tech Discussion
    Last Post: 05-11-2010, 08:59 AM
  3. New guy with a few car problems......lol
    By jigwynn in forum Introductions/Noob Questions
    Last Post: 04-24-2010, 10:58 PM
  4. So many problems. . .
    By SDGTP99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2010, 02:09 PM
  5. I've got problems...
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2010, 06:48 PM
