Thread: DIC problems!!!!! HELP!!!!
Results 1 to 12 of 12
  1. #1 DIC problems!!!!! HELP!!!!
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    I have a 98 gtp and whenever i try to turn the fan on for heat or a/c my DIC goes out, fan shuts off, and so do my headlights.. (totally sucks at night lol) any info would be great! trying to get this fixed by the time winter comes around
  2. #2 Re: DIC problems!!!!! HELP!!!!
    GTP Level Member SuperSport's Avatar
    Michigan
    Sounds like a bad ignition switch.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: DIC problems!!!!! HELP!!!!
    Waterloo, Iowa
    hey anyone else know what this could be? it happened to me last night coming home and the windshield was frosted as hell and i had a 2in by 2in spot to see through the windshield
  4. #4 Re: DIC problems!!!!! HELP!!!!
    Charles City, IA
    I would secound the ignition switch. Being that the dic headlights and blower motor are not in the same system.
    SMGPFC Two Nipple General
  5. #5 Re: DIC problems!!!!! HELP!!!!
    Waterloo, Iowa
    how much will that set me back?
  6. #6 Re: DIC problems!!!!! HELP!!!!
    Seattle
    Look at OEM Chevy Parts - GMPartsClub.com It looks to be around 92 bucks + shipping.
  7. #7 Re: DIC problems!!!!! HELP!!!!
    O!..NEB
    just curious as what you did to fix this..I have a 98 gtp and it does this too. Very annoying haha
  8. #8 Re: DIC problems!!!!! HELP!!!!
    SE Level Member ctrout's Avatar
    Feb 2010
    Idaho
    I had the same problem last fall and everyone said ignition switch. I kept troubleshooting and was convinced that it was the fan switch. I replaced it and the problem went away. How I nailed it down was, once it got to where the problem became constant instead of intermittent, I disconnected the harness from the fan switch and it went away. I turned the switch to off and plugged it back in. The problem was still gone. When I turned the fan switch on, problem came back. Unplugged switch and the problem went away. Lather, rinse, repeat.
  9. #9 Re: DIC problems!!!!! HELP!!!!
    O!..NEB
    ok yeah right now its been just like the light isnt coming on the dic but if i shine like a flashlight on it i can tell its working cause i can see it but its just not lighting up but every once in awhile it will start messing everything up like making my headlights go off and on and shutting my fans off but it used to do it everyday so idk
  10. #10 Re: DIC problems!!!!! HELP!!!!
    Feb 2010
    Idaho
    Yes, mine had EXACTLY the same symptoms. Changed the heater blower switch and it has worked great now for 6 months.
  11. #11 Re: DIC problems!!!!! HELP!!!!
    O!..NEB
    Haha ok thanks guys saved me a lot of trouble. ^_^
  12. #12 Re: DIC problems!!!!! HELP!!!!
    Waterloo, Iowa
    you guys think doing the ignition switch bypass mod would work?
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  1. A/c Problems
    By TripleZero in forum General Tech Discussion
    Last Post: 08-12-2010, 10:57 AM
  2. A/C problems
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 11:04 PM
  3. HID Problems
    By That Guy in forum Visual/Body Modifications
    Last Post: 05-19-2009, 10:58 PM
  4. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
  5. More problems?!?!?!?!?
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 11-01-2008, 01:09 AM
