Thread: oil pressure problem?
Results 1 to 20 of 24
  1. #1 oil pressure problem?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    my oil pressure light will come on sometimes and so will the seat belt light there will be chiming, and sometimes the hvac will come on when the cars off and stay on until i pull the fuse, im completely lost and have no idea what to do
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: oil pressure problem?
    Easiest way to tell if you actually have oil pressure or not...
    Is go to your local auto parts store and put a mechanical gauge on there and have someone keep an eye on it.
  3. #3 Re: oil pressure problem?
    Oct 2011
    Michigan
    I'm pretty sure I have oil pressurei drove it home and didn't here metal to metal
  4. #4 Re: oil pressure problem?
  5. #5 Re: oil pressure problem?
    Eh...he'll know in a couple of days.
  6. #6 Re: oil pressure problem?
    Oct 2011
    Michigan
    I think the pressure switch wemt bad and they didn't have an gauges for mycar
  7. #7 Re: oil pressure problem?
    Guy, its a universal Sunpro gauge in the ricer aisle for like 15-20 bucks. It's got a feed line and you just tap it into the oil filter housing after you drain the oil and remove the oil pressure sensor.
  8. #8 Re: oil pressure problem?
    Oct 2011
    Michigan
    alright im pretty sure its the oil pressure sending unit though im gonna try changing that first, on a side note if i pull my HVAC fuse from the glove box the light will go off and stay off
  9. #9 Re: oil pressure problem?
    When you go to do the sensor.. channel lock pliers work best.
  10. #10 Re: oil pressure problem?
    Oct 2011
    Michigan
    thanks! i was just think i dont have a wrench that big lol you think a lot of oils gonna come out? i have about 1.5 qts left from my last oil change so i hope thats enough
  11. #11 Re: oil pressure problem?
    some oil will spill out when you pull the stock sensor, have a small pail ready. no more than a 1/4 quart or or less will come out.
  12. #12 Re: oil pressure problem?
    Oct 2011
    Michigan
    alright im gonna try that im gonna clean up my chassis grounds as well to try to fix these problems and on an unrelated note im gonna change my brake fluid mines is almost black
  13. #13 Re: oil pressure problem?
    yeah..it's not much oil. Enough that you want a small catch thingee under it. I usually sit there with the wheel off, pail between my legs and look like I'm hugging the rotor.
  14. #14 Re: oil pressure problem?
    you short armed folks lol i just remove the tire and just reach in, done. no need to put my legs under the car lol but i got a good mental pic of bill description.
    i have a friend whos way over weight, (like 400+) he was able to take the alt off his truck but unable to reach the bolt under the alt to finish putting it back on, i called him T rex arms lol as i had both arms all the way down to the bolt lol friggin Toyota's.
  15. #15 Re: oil pressure problem?
    I'd like to see how you postition your neanderthal body in order to do it, then. I have the car jacked up and get comfy. It's easy enough and right there. Since I'm normal sized and you are from the amazon... wanna tell us how you situate yourself? Do ya lay on yours stomach?
  16. #16 Re: oil pressure problem?
    on my knees, reach in to it, and work them channel locks like a pro....ive had to deal with mine leaking 3 times, got sick of replacing them and plugged the hole with a brass plug. i think it cost 60 cents.
    i need a nice new gauge myself, one of these days, yeah someday lol
  17. #17 Re: oil pressure problem?
    On your knees...is the car on a lift? hahahaha
  18. #18 Re: oil pressure problem?
    lol good one. i've been called Jeffery as well, you know the toys r us baby giraffe.
    i wish i had a lift.
  19. #19 Re: oil pressure problem?
    If you kneel next to a Regal, your shoulder is higher than the fender. How's kneeling work for .... oh wait...I think I figured it out.
  20. #20 Re: oil pressure problem?
    im actually chest height, i need to bend over some and reach in with my left arm head towards the bumper lol
    no bob and kneel lol
  1. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  2. Fuel Problem 1/2 pressure?
    By Z34Phoenix in forum General Tech Discussion
    Last Post: 09-25-2011, 10:22 AM
  3. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  4. vacuum pressure problem
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 11:47 AM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
