Thread: oil pressure problem?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #1 Re: oil pressure problem?
    Did you kneel or sit?
  2. #2 Re: oil pressure problem?
    LOL... thought you'd like that text
  3. #3 Re: oil pressure problem?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    lol you guys haha well i changed the sending unit and the light went away so problem solved i guess
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  4. #4 Re: oil pressure problem?
    Oct 2011
    Michigan
    i sat legs under the car.....they get sprayed with oil my catch pan was poorly placed
  1. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  2. Fuel Problem 1/2 pressure?
    By Z34Phoenix in forum General Tech Discussion
    Last Post: 09-25-2011, 10:22 AM
  3. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  4. vacuum pressure problem
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 11:47 AM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
