Is there a certain way to mount the icm, coils on a angle so doesnt hit the sc belt
just loosen the top bolts and put washers behind them and tilt it up. That's what I did and it works great. Or get the bonneville bracket, which I plan on installing soon.
Go to the hardware store and look for bolt spacers, then get a longer bolts for the ICM bracket.
Is it had to install the bonneville bracket
I had it done a while back but just installed a cam and when i idle it makes a squeaky noise and tried to tighten the washers but still has little play side to side so maybe the bolt aint fitting right
Sam - every intercooled car youve ever seen in person had their coil packs spaced the way I did yours =p. Next time I see you I will check it out and make sure its tight and not squeaking. .
Go here and view the second PDF called "S2 S3 Intercooler installation instructions v.2.pdf". ZZPs instructions actually show what I did to yours.
http://s3.amazonaws.com/zzpstorage/i...IC+Install.zip
