Thread: 24 mm bolt on crank?
Results 1 to 11 of 11
  1. #1 24 mm bolt on crank?
    Dec 2011
    cali
    We had a write up on here bit the links broke I seen thateveryone on here sad that that bolt was hard but something in the write up made it easy!??? We are replacing crank pos sensor ... Anyone know what the secret is that has done this before??
  2. #2 Re: 24 mm bolt on crank?
    Charles City, IA
    good impact. or put a breaker bar on the bolt and bump the engine with the start after disabling spark and fuel.
    SMGPFC Two Nipple General
  3. #3 Re: 24 mm bolt on crank?
    Dec 2011
    cali
    That sounds scary lol where do we wedge the bar? What do you mean disable the pull how would we start it? Could you explain in dummy terms?
  4. #4 Re: 24 mm bolt on crank?
  5. #5 Re: 24 mm bolt on crank?
    Dec 2011
    cali
    T for the vid! Got it on to pulling it now with the balancer puller the volts thread into the 3 holes??
  6. #6 Re: 24 mm bolt on crank?
    Mar 2012
    NC
    Yup...make sure you have the right bolts though.
  7. #7 Re: 24 mm bolt on crank?
    http://www.grandprixforums.net/how-r...sor-60906.html
    Boomski.
    The bolts are M6x100.
    They kinda go in at an angle fyi.
  8. #8 Re: 24 mm bolt on crank?
    Dec 2011
    cali
    I think we may have it we have a universal kit
    Ohio
    Yeah everyone thinks that they have it in the universal kit... It's not there.
  10. #10 Re: 24 mm bolt on crank?
    Dec 2011
    cali
    Quote Originally Posted by 99pgpgt View Post
    yes those bolts sucks and started stripping on us.. so tomorrow ill ahve to go to the home depot and get new bolts.. sucks!!
  11. #11 Re: 24 mm bolt on crank?
    You will chase around forever trying to find M6 x 1.00 x75mm's. You can also use 1/4" fine pitch thread. It's not exact...but it sure works fine when you can't find m6 in the length.
  1. Crank Bolt Will Not Come off
    By BoilerTom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2012, 08:03 AM
  2. problems removing crank bolt from hub
    By BonesSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 07:50 PM
  3. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
