Thread: Post Top Swap Issues 2005 GT
Results 1 to 10 of 10
  1. #1 Post Top Swap Issues 2005 GT
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Everything is rolling along great in the GT but last night I wanted to connected to BCS wire into the PCM harness. I did this and the thing still doesn't work. I will assume its the ZZP computer and it may not be programmed to have the BCS, but any other options/opinions would be appreciated. I can tell you the PCM is programmed to use a GT map and not a GTP so I wont be able to read boost electronically, not sure if that has anything to do with it. I have the pigtail for the BARO sensor and the sensor but I see no point in wiring it in as I doubt ZZP put the option in the PCM as well. I'm stuck any ideas? I was going to take the BCS off of my moms 2001 gen3 as I know it is good and connect it to my car and see if their is any change. But as of now when the car is at idle the valve is half closed and doesn't change at any speed/rpm.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Post Top Swap Issues 2005 GT
    Apr 2012
    Middletown DE
    In case you were wondering how I kept my BCS closed before. Its a stupid idea and looks like ass
    1993 Oldmobile 88
  3. #3 Re: Post Top Swap Issues 2005 GT
    take the vacuum line off there, leave the solenoid open to the air. it'll give you full boost.
    cap the vacuum line or shorten it to end at the FPR so you dont have a vacuum leak.
    i would wire the MAP in (baro, as you referenced it).
  4. #4 Re: Post Top Swap Issues 2005 GT
    Apr 2012
    Middletown DE
    I dont understand why the L32 has two map sensors one for map and one for baro. I can kinda guess why but i am probably wrong.
    1993 Oldmobile 88
  5. #5 Re: Post Top Swap Issues 2005 GT
    Baro gives it the atmospheric pressure and map gives it the pressure in your manifold. It compares them
  6. #6 Re: Post Top Swap Issues 2005 GT
    Apr 2012
    Middletown DE
    What is the computer doing with that data?
    1993 Oldmobile 88
  7. #7 Re: Post Top Swap Issues 2005 GT
    and you dont have a FPR on your fuel rail either, i'm dumb.
  8. #8 Re: Post Top Swap Issues 2005 GT
    Nope, returnless system gai.
    '04+...yippeee
  9. #9 Re: Post Top Swap Issues 2005 GT
    Using it for calculations of fuel/air density blah blah.. it's all in the programming. I don't have a good answer off my head. But if you look up a baro code in the FSM it'll tell you exactly what it's used for.
    Bio...you said it...not us. It's ok, you are on the previous gen.
  10. #10 Re: Post Top Swap Issues 2005 GT
    Feb 2009
    flintnasty MI
    a GT file will not support a BCS or a baro sensor.... Dont try to use them.
    The bbv just needs to have vac to the top of the canister, leave the bottom open and remove everything else.
  1. 2005 GPGT Top Swap Log
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2012, 01:48 PM
  2. 2005 gp transmission issues Help
    By grandprix5 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2012, 08:46 AM
  3. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  4. I have some issues after Top Swap NEED INPUT
    By WindsorGP in forum General Tech Discussion
    Last Post: 08-17-2010, 05:35 PM
  5. 2005 Grand Prix Transmission Swap???
    By timpuparts in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-18-2010, 07:05 PM
