Thread: 2005 gp transmission issues Help
Results 1 to 12 of 12
  1. #1 2005 gp transmission issues Help
    GT Level Member grandprix5's Avatar
    brownsville
    hello i have a 2005 grand prix se and im starting to have issues with my tranny everytime i turn right the tranny starts sliping and i dont have that issue when i turn left also sometimes when i make a fast complete stop the car goes in to neutral for about 5sec do anyone had a problem similar
  2. #2 Re: 2005 gp transmission issues Help
    Kansas
    Been doing a lot of burnouts going around a right corner?
  3. #3 Re: 2005 gp transmission issues Help
    Ohio
    check your fluid.
  4. #4 Re: 2005 gp transmission issues Help
    brownsville
    before this happened i changed the transmission fluid and today when i check the transmission fluid its a little over do you think a little over would cause that problem ?
  5. #5 Re: 2005 gp transmission issues Help
    GT Level Member Fraschy's Avatar
    Aug 2011
    Sheboygan, Wisconsin
    You did a pan drop and filter change you mean?
    1994 Grand Prix GTP - Dead
    1995 Grand Prix SE Coupe
    2007 Pontiac Torrent
  6. #6 Re: 2005 gp transmission issues Help
    brownsville
    and all this happens (acationlly)(sometimes) not all the time !
  7. #7 Re: 2005 gp transmission issues Help
    brownsville
    yeah i changed the filter and the oil
  8. #8 Re: 2005 gp transmission issues Help
    Aug 2011
    Does it vibrate when you come out of turns? You mean it only goes into neutral while you are hitting the breaks? The neutral thing is what scares me..that more than likely means your tranny is about to go out. It's really hard to say.
  9. #9 Re: 2005 gp transmission issues Help
    brownsville
    also i was thinking in swaping the tranny to a 4T65E-HD would i need and modification since i have the non HD or could i be able to pull it out of a gtp and put it on my car ?
  10. #10 Re: 2005 gp transmission issues Help
    brownsville
    ok well (smetimes) when im driving and do a complete stop the car goes to neutral for 3-5 sec after that the car goes into gear and everything its normal ! no issues after that but also sometimes when i turn to the right the tranny starts sliping like it goes into gear and then neutral -gear-neutral- until i go straigt but both issues happen only in some ocations not all the time and besides that the car runs fine in all gear shift points
  11. #11 Re: 2005 gp transmission issues Help
    Quote Originally Posted by grandprix5 View Post
    abs/trac light on? or the low trac light flashing on? is the wheel spinning like when your getting on it on loose gravel? or just when you drive it normal does it slip or chatter?
    almost seems like traction control is kicking in. vid maybe?
  12. #12 Re: 2005 gp transmission issues Help
    Winfield, Mo
    I am very happy that I found this site... I was searching for info on a hx35 on a grand prix. Found this thread and laughed. I was looking for that info because this person has their grand prix up on craigslist. Now I know the reason he is selling it now is because of transmission problems. I read all of the other posts he made and realized that he is completely retarded. I guess I should post something up on craigslist about this... Wow. I'm assuming this car has been through alot of abuse and not much maintence...
  1. Transmission Issues....Help!!
    By Chad C in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-27-2011, 10:58 AM
  2. '06 GT Transmission issues
    By thomas91169 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-04-2011, 06:08 PM
  3. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  4. 2005 Grand Prix Transmission Swap???
    By timpuparts in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-18-2010, 07:05 PM
  5. 2005 transmission same as 2001?
    By mxzx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-02-2009, 08:13 PM
