Thread: Replaced A/C compressor
Results 1 to 20 of 38
  1. #1 Re: Replaced A/C compressor
    I did mine at the same time as my headers so it only took about 20 min. Never done one other than that though.
  2. #2 Re: Replaced A/C compressor
    Jan 2012
    Abilene, KS
    and i would suggest that unless you see it coming straight from the compressor just try replacing the o ring first and if that dont work then you should replace the o rings anyways so its not like you would be wasting any money.
  3. #3 Re: Replaced A/C compressor
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Looks like the oil is coming out the front, clutch area of the compressor. I will crawl under and see if the hoses are leaking also.
    Oil is being slung out like it is being spun by the clutch. If it was the hoses would it be more towards the back of the comp ?
    1997 Red GTP 182000 miles stock
  4. #4 Re: Replaced A/C compressor
    Jan 2012
    Abilene, KS
    One more question which side is the high side and which is the low? Which side do i fill?
  1. Replaced hub. Now have problem.
    By twoleos617 in forum General Tech Discussion
    Last Post: 11-02-2011, 01:16 PM
  2. what else should be replaced?
    By meoneal in forum Brakes/Suspension/Chassis
    Last Post: 06-06-2011, 03:33 PM
  3. Replaced hub car still humming
    By Cbierniat24 in forum General Tech Discussion
    Last Post: 04-27-2010, 10:28 PM
  4. I replaced the Oxyg sensor now what
    By lfernes in forum General Tech Discussion
    Last Post: 11-30-2009, 08:45 AM
  5. Replaced LIM Car Wont Start
    By gprixster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2009, 04:56 PM
