Quote Originally Posted by massivesystem View Post
So I ordered a PCM and other items from from overkill last week and I was talking to Will and he stated that if you keep the stock box which comes in three sections and gut out the center to equal the entire sizes of the stock filter, and then remove the 3rd part of the box that sits behind the headlights and cut it to equal the true opening. Then drop in a cone (4x9)
True it does not have the looks of a Wizaired or a cold air inductions box but, you have a very large opening inside of the stock air box which should provide equal performance.
Yes/NO ?
Comments.
Unless posters are scanning and giving you numbers you are going to get allot of inferences and opinions about this rather then some actual evidence.
That being said my opinion is that the stock air box would heat soak allot easier and faster then would a Wizaired and a Cold air inductions box. The plastic is more dense then the insulation on the later two and therefore wouldn't transfer heat to the environment as easily. Also [if your taking off the part i'm thinking of], you would get allot of heat from the engine compartment thus effectively making your CAI a HAI.
