Thread: Amsoil Cone Filter
Results 1 to 8 of 8
  1. #1 Amsoil Cone Filter
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    What is the proper Amsoil Ea cone filter that I will need for my wizair.
    Is it the EaAU4090?
  2. #2 Re: Amsoil Cone Filter
    Feb 2008
    South Bend, IN
    I believe its 4090.
  3. #3 Re: Amsoil Cone Filter
    Oklahoma
    If you give me the dimensions of the opening on the tubing and the length I'll find out which one you need.
  4. #4 Re: Amsoil Cone Filter
    Barksdale AFB, LA
    The WizAired uses a filter with a 4" opening, 6" base width, and 9" length.
    Edit: Here's the K&N so you can compare dimensions:
    http://www.knfilters.com/search/prod...x?Prod=RE-0870
    2009 Subaru Impreza WRX STI
  5. #5 Re: Amsoil Cone Filter
    Feb 2008
    South Bend, IN
    Thanks for the replies. KN 0870 = Amsoil 4090.
    I just noticed that the KN filters dont have an opening on the top of cone like the S&B and Amsoil cone filters. Seems like it would be more beneficial to have the opening on top of the cone for increased air input?
  6. #6 Re: Amsoil Cone Filter
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I would even use one of those.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  7. #7 Re: Amsoil Cone Filter
    Oklahoma
    I was a LONG time user of Amsoil foam filters and LOVED them. When Amsoil revamped their filter line up I was initially kinda hesitant. But after finally putting one on and getting an oil analysis after using it for a while and seeing a reduction in silicone, Im pretty happy with it. They are still good for 4yrs or 100,000 miles and you dont have to worry about contaminating your MAF sensor.
    I never had a problem with that but I have run across many that did so I think the current Amsoil filter will help aleiviate that.
  8. #8 Re: Amsoil Cone Filter
    Feb 2008
    South Bend, IN
    Yea after doing some research online of the Nanofiber material that the Amsoil cone filters are made of, its pretty much a given that its the way to go. Plus it doesn't use oil, my KN drop in was soaked when I took it out of the package. I can't wait to get that thing out of there.
  1. Amsoil in the S/C
    By TDCRacing in forum General Tech Discussion
    Last Post: 08-18-2008, 08:25 AM
  2. What K&N Air Filter To Use
    By SG2000GTP in forum General Tech Discussion
    Last Post: 06-01-2008, 06:00 PM
  3. Anyone have an S&B filter?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-12-2008, 07:18 AM
  4. Cone filters
    By bat119 in forum General Tech Discussion
    Last Post: 02-27-2008, 06:00 PM
