Thread: VS cam pulley size?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
  1. #1 VS cam pulley size?
    Quincy, Mass
    how small of a pulley could i run with the VS cam, zzp stg3 heads (130# springs), 1.7rrs, ICed, GenV? basically the mods in my sig with the VS instead and TOGs instead of slps.
    please no stupid replies like "as small as you want"
    No more GP 04 Impala SS Indy:
  2. #2 Re: VS cam pulley size?
    I'd say its up to the car.
  3. #3 Re: VS cam pulley size?
    Quincy, Mass
    not the kind of answer im looking for...
  4. #4 Re: VS cam pulley size?
    well, it's true. the only way you'll know is have a plethora of pulleys and to see what the car can run without knocking.
  5. #5 Re: VS cam pulley size?
    Quincy, Mass
    ok so i could potentially go to a 2.55 with this cam? i have a plethora of pulleys to try out on it and would like to be running a low one. what size should i start with?
  6. #6 Re: VS cam pulley size?
  7. #7
    Quincy, Mass
    Ok good, thats the biggest one I have
  8. #8 Re: VS cam pulley size?
    Saratoga NY
    3.4 is way to big.
    I would think a 2.8 would be a decent starting point, should be able to run healthy amount of timing and afr.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  9. #9 Re: VS cam pulley size?
    VS instead of IS3.... Interesting.
    3.2-3.4 is a nice starting point.
    Getting boost levels up to 10 PSI, maybe a tad more, solid AFR around 11.4-11.6, 16-19* timing would be a nice reliable "street" goal.
  10. #10 Re: VS cam pulley size?
    Quincy, Mass
    thanks matt. reliable is what im going for this time.
    i was going to build a second motor with the vs in case the is3 motor blew. well yesturday it blew so im going to go with the vs and probably sell the is3 cam. is3 was fun but time for some more reliable on the street, gas is getting pricey
    Mercer, Pa
    Im running 3.25 on similar setup with l26 bottom end. 0 kr on 93 octane almost like it doesn't work. 2 kr on 89 octane, put 5 gallons in to see how close I'm on pulley size. My timing appears to be 19 or 20 degrees and it was 60 degrees out. Still need to get this tuned.
  12. #12 Re: VS cam pulley size?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I'm gonna say 2.8-3.0....3.0 easily. I'm able to run a 2.8 with a GenV and stock heads with the help of E85. With having those heads and an IC I'd say 2.8 on pump gas is easily do-able.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  13. #13 Re: VS cam pulley size?
    Quincy, Mass
    on the S1x or on a VS?
    i have down to a 2.6 so it would be nice to drive around on the 2.8.
  14. #14 Re: VS cam pulley size?
    Feb 2009
    flintnasty MI
    2.8 if you put stock rockers back on..
    If you leave the 1.7s on... Probably a 3.2 would be all you can do before you start floating.
  15. #15 Re: VS cam pulley size?
    Apr 2011
    Columbus, OH
    I was able to do the 2.8 with the SIX. The SIX is just slightly more aggressive than the VS cam.
    I didn't see the 1.7 RR earlier in your post. You will for sure be able to run the 2.8.....Maybe even shoot for the 2.6
    VS cam with 1.7 RR = more lift than VS cam with stock rockers....I don't see why he would run a bigger pulley. Should be the other direction and run a smaller pulley.
    Valve float won't be an issue with 130# springs. Even with the VS and 1.7RR combo it's about the same lift as a stage 3 cam.
    VS: 206/216 .320/.317 115 N/A Total lift = .512/.507
    VS w/1.7RR: 206/216 .320/.317 115 N/A Total lift = .544/.539
    IS3: 222/228 .338/.344 115 111 Total lift = .541/.550
    With duration out of the question he is essentially running a combination that has roughly the same amount of lift as an IS3 cam.
  16. #16 Re: VS cam pulley size?
    Quincy, Mass
    Quote Originally Posted by Quick99GTP View Post
    its about the same lift as a is3 with stock rockers. i was running the 1.7s with the is3 too.
  17. #17 Re: VS cam pulley size?
    Apr 2011
    Columbus, OH
    Quote Originally Posted by Swiggles View Post
    You beat me to it...I was editing my last post to show that.
    I'm in a similar situation with my build where I am going to be combining the SIX with 1.8 RR for a nice DD setup.
    The VS with 1.7 will be a nice setup with the nice set of heads that you're pairing that combo with.
  18. #18 Re: VS cam pulley size?
    Feb 2009
    flintnasty MI
    Uh, 1.7 roller rockers make LESS lift than stock, and have been proven to float like crazy on 130# springs even at low lift.
    Confused why anyone would want to try to run more boost to counter act **** parts.
  19. #19 Re: VS cam pulley size?
    Quincy, Mass
    Well new news to me.
    How do 1.7 rockers make less lift than stock?
  20. #20 Re: VS cam pulley size?
    Feb 2009
    flintnasty MI
    Stock rockers are variable ratio. On a XP cam I measured roughly a 1.78 ratio at full lift. A 1.7 roller will lose some ratio at peak lift... I was not able to measure it accurately though.
    The last motor I built with rollers used 1.8s, custom rocker bolts, custom lifters, and a xpz style cam on double spring 150# springs.... I still think it floated slightly passed 6400rpms so i shifted it at 6200 instead of the targeted 6600....
  1. Pulley size?
    By RobGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2011, 08:14 PM
  2. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  3. what pulley size to go with next mod?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2010, 06:28 PM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
