Thread: Top swap MAP question
Results 1 to 7 of 7
  1. #1 Top swap MAP question
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I have a 1999 Grand Prix GT which I just top swapped. I read if you use an L36 bin, you should use an L36 MAP. I don't have the adapter harness for the L67 MAP, and ZZP wants to charge me like $60 shipping on top of the harness. Should I just leave the L36 MAP, or splice in an L67 MAP? Would it work with my tune?
  2. #2 Re: Top swap MAP question
  3. #3 Re: Top swap MAP question
    Quincy, Mass
    the l32 map sensor works on the l36 harness doesnt it?
    No more GP 04 Impala SS Indy:
  4. #4 Re: Top swap MAP question
    Mar 2012
    NC
    Yes, the L32 MAP is plug and play.
  5. #5 Re: Top swap MAP question
    Quincy, Mass
    and then you just run an l67 file or an l36 file with the l32 map?
  6. #6 Re: Top swap MAP question
    Mar 2012
    NC
    You run the L67 file with the L32 MAP. There are other parts of the tune that will most likely need to be adjusted as well, but that will take care of the MAP problem.
  7. #7 Re: Top swap MAP question
  1. DIC Swap Question
    By Tremayne0126 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2022, 07:35 AM
  2. Gen V swap TB question
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2012, 10:59 AM
  3. Top Swap'n Question
    By BillBoost37 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2011, 08:06 AM
  4. top swap question.
    By turbo6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:14 PM
  5. ....And yet another Top Swap Question...
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2010, 06:27 AM
