Thread: top swap question.
Results 1 to 6 of 6
  1. #1 top swap question.
    Central Florida
    i have done a good bit of reearch into this but cat figure these things out
    1. a local speed shop mechanic said i didn't need a tune since i already have the GTP computer (meaning only the N/A computer needs a tune.)
    2. what modifications do i need to do in order to safely use the higher compression engine? im already planning FWI, headers and maybe some port cleaning up
    thanks in advance!
    1998 Pontiac GTP - rebuilding
    1991 Mazda MX6 GT - DD
  2. #2 Re: top swap question.
    the L67 PCM cant control your L36 transmission. did they tell you that?
    headers should be good to go for the stock pulley, but anything beyond that and you'll want more to satisfy the flow needs of the engine.
  3. #3 Re: top swap question.
    Jersey
    I'm using a gtp bin file now, works just fine, actually way better than my modded gt file. just need to get the 3.29 tuned in there
    16' wrx sti- stock
  4. #4 Re: top swap question.
    Central Florida
    the transmission is what came with the car originally with the engine, so it should work(it is a GTP)
  5. #5 Re: top swap question.
    Jersey
    Quote Originally Posted by turbo6 View Post
    oh, i didn't realize you had a gtp already, you might have to tune it so it's less aggressive
    16' wrx sti- stock
  6. #6 Re: top swap question.
    Central Florida
    so if i swap it, headers and FWI i should be ok, but should get a tune to be safe.
    Quote Originally Posted by 99prixgt View Post
    its all good man!
  1. ....And yet another Top Swap Question...
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2010, 06:27 AM
  2. Top Swap Question
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2009, 06:34 PM
  3. Blower swap question
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2009, 01:59 AM
  4. another top swap question
    Last Post: 02-20-2009, 12:59 PM
  5. LOL another top swap question
    Last Post: 01-21-2009, 05:40 PM
