Starting about a month ago when the weather started to warm up, I noticed the air conditioner didn't feel nearly as cold as it did the previous summer. So I took out my gauges thinking it just needed a charge. It did not. The next week my wife and I were driving to Houston for the week. She started complaining it was too cold. I'm thinking, what the hell, it's hardly cooling down on my side. So I reached over to feel her vent and guess what, it is ICE COLD. The vents on the drivers side barely blow any cool air. I can turn it to heat and it will burn you out. Turn it to cold, not so much. But the passenger side vents blow freezing air when the A/C is on...strange huh? A week later, I noticed even with the climate control off, I would occasionally see the symbol for the air coming out the vents being displayed. It would flicker on and off. Strange as well. Now today, I leave work and turn the A/C on. Nothing. I could hear the compressor kicking on, but the blower motor would not engage. I left it on to see what would happen. The first time I hit a bump, the blower motor came on. I am suspecting a loose connection somewhere. Sadly, the bump didn't fix the cold air not coming out the drivers vents.
Soooo...has anyone had this issue before? I am not very familiar with the dual climate control systems. I would guess one or more of the "flaps" inside the control box are not opening or closing properly. Other guess might be the controller is on its way out. Any help is appreciated. Thanks!
