Thread: GenV intercooler low on boost
Results 1 to 8 of 8
  1. #1 GenV intercooler low on boost
    GT Level Member lilrocket's Avatar
    landis,nc
    ok just installed the genv supercharger and stage 2 intercooler so the mods are as follwed 1.9 roller rockers, 105lb springs, 42.5 injectors, headers, full exhaust, cia, pcm, mps ok i have the 3.2 pulley on it to scan it i have like 16 lbs of vacuum but im only making like 9lbs of boost with the 3.2 pulley does this sound right with it having a intercooler new to the intercoolers runs strong just seems a little low on boost being i was running 12 on a 3.4 on the gen 3 with no intercooler
    98 DAYTONA 1110/1500: work in progress
    00 DAYTONA 216/2000: totaled but not forgotten parts car
    "Speed its my drug, the faster i go, the faster i want to go!"
  2. #2 Re: GenV intercooler low on boost
    Because an intercooler is technically a restriction.
    And rockers/headers help flow.
    I saw 11-12 on a 3.0" with no intercooler, but ported heads and a big cam. So, it sounds about right.
  3. #3 Re: GenV intercooler low on boost
    landis,nc
    ok just checking wasnt 100% sure i mean it pulls harder just seemed low on boost and getting zzp on the phone is like impossible, also think i might have a little belt slipage
  4. #4 Re: GenV intercooler low on boost
    Try swapping belts if you want, but basically...when you are flowing better you aren't making as high of boost numbers. All boost is...is a measure of restriction. These motors tend to run great around 8-12 psi....so it sounds like if you aren't knocking, try a 3.1" or even a 3.0". Might help get the boost numbers up a little...but too much boost is just going to heat soak that IC and cause more parasitic loss from the smaller pulley.
    How's that?
    Ohio
    How's that?
    Marvelous
  6. #6 Re: GenV intercooler low on boost
    Thanks guy.
    Knew I could count on you, bewbies.
    Ohio
    The hoodz got yo back son
  8. #8 Re: GenV intercooler low on boost
    landis,nc
    lmao thanks for the help lol
  1. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  2. intercooler and boost
    By blowfishRus6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 09:35 PM
