Thread: New top-swap...6 deg. Knock at WOT
Results 1 to 14 of 14
  1. #1 New top-swap...6 deg. Knock at WOT
    SE Level Member rell2005's Avatar
    Detroit / Grand Rapids
    Aight car guys...The newly top-swapped GT on a 3.4 pulley and headers running 93 read 6 deg. knock at WOT tuners for some reason wouldn't read RPM, Boost, A/F, gear, trans temp, and injector pulse width. Other than at WOT, she runs fine. Were thinking is has something to do with Air/Fuel, but not sure on anything yet.....ANY IDEAS????????
    Also an S2IC kit it attached but not running yet, waiting on a IC pump to come in the mail.
    New top-swap...6 deg. Knock at WOT Attached Images
  2. #2 Re: New top-swap...6 deg. Knock at WOT
    to big of pulley to start with.
    you are on a high comp block.
    bump to 3.8
  3. #3 Re: New top-swap...6 deg. Knock at WOT
    Out West
    bigger pulley, guy.
    headers arent even enough for a 3.4 on a LOW comp block.
    Whine with your Cheese?
  4. #4 Re: New top-swap...6 deg. Knock at WOT
    I had a 3.6, but we couldnt get the dam belt over the pulley, thought it says a 685 should fit over a 3.6
  5. #5 Re: New top-swap...6 deg. Knock at WOT
    Jersey
    you need stock pulley 3.8" size, nothing else.
    16' wrx sti- stock
  6. #6 Re: New top-swap...6 deg. Knock at WOT
    Feb 2009
    flintnasty MI
    the intercooler should let you run a 3.4, but you most likely have almost ruined it by running without coolant in it. Those cores are not designed to handle the 300+ degree temps that the blower outputs.
  7. #7 Re: New top-swap...6 deg. Knock at WOT
    The IC is fine. its filled with coolant and i havent put hardly any miles on it since i live 2 miles from my job.
  8. #8 Re: New top-swap...6 deg. Knock at WOT
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    Ouch, never go WOT without an intercooler pump going. Not good. Who did the tuning? hit up Zach Brunsink on my facebook, he did the tuning on my IC set up and I run a 2.8 with my XP cam and see 0 knock and she runs damn good.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  9. #9 Re: New top-swap...6 deg. Knock at WOT
    Also the blower has only been running for a few days now and ive intentionally been staying out of the boost
  10. #10 Re: New top-swap...6 deg. Knock at WOT
    Feb 2009
    flintnasty MI
    but you have tons of knock and wonder why..... DOES NOT COMPUTE
  11. #11 Re: New top-swap...6 deg. Knock at WOT
    Knock only registers at WOT, which was once and hasnt been at WOT since...computes just fine my friend.
  12. #12 Re: New top-swap...6 deg. Knock at WOT
    Out West
    then don't worry about it.
    but ask yourself what's the point of even having the top swap if not using the power.
  13. #13 Re: New top-swap...6 deg. Knock at WOT
    Quote Originally Posted by Nixon View Post
    Didnt know was the knock from the pulley or something else, but now I have an idea.
  14. #14 Re: New top-swap...6 deg. Knock at WOT
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    why is this even a thread?
  1. Is it knock?
    By radiocrash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2012, 12:30 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. Top Swap knock
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2009, 08:15 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
