Thread: Picking the right engine question.
Results 1 to 9 of 9
  1. #1 Picking the right engine question.
    Nov 2011
    Ohio
    So I done some looking and cant find a good answer, I need a new motor and my dad found a normal 3.8 n/a. What he was told was any 3.8l 97 to 03 sc or n/a will work is this correct? also if the 8th number on the vin is a number one then you can swap out for any 3.8 is this also true? lastly any thing extra required when adding all your s/c parts to a n/a ? thanks!
  2. #2 Re: Picking the right engine question.
    First. What motor do you have? Or car?
    Second. Buy a motor that you car needs. Supercharged L67 and NA L36. If you are SC now, buy a L67 short block.
  3. #3 Re: Picking the right engine question.
    the easy thing to do is to just get a s/c engine and swap it, but if you cant find one, you can find a N/a block, and top swap you parts to it, heads manifolds, and the whole front of your engines pulleys and parts. but you would also want to add headers to your rebuild to let the engine breath better, being that you at now using a high compression block. and a get the pcm tuned.
  4. #4 Re: Picking the right engine question.
    Nov 2011
    Ohio
    I have headers on the car 3.4 pulley 3800performance pcm. I have a 2002 3.8lt sc found a low mile 3.8 n/a for $300
  5. #5 Re: Picking the right engine question.
    top swap it with your parts, get a 3.8 pulley back on it, and have your pcm re tuned. done deal.
  6. #6 Re: Picking the right engine question.
    Nov 2011
    Ohio
    well I dont have a pulley puller and where would I go to get a tune ?
  7. #7 Re: Picking the right engine question.
    i would call 3800 performance and see what they could do for you if their pcms are locked you may have to send it back to them. but i see you are in ohio, so you could be close to a # of people from here who tune. if you have your stock pcm, they could tune that one.
    there is a guy selling pulley pullers in the for sale section take a look there. he makes them and sells them at a fair price it seems to me.
    heres the link to the puller. http://www.grandprixforums.net/pheno...ler-42711.html
  8. #8 Re: Picking the right engine question.
    I still have that l67 short block laying in the garage if you interested.
  9. #9 Re: Picking the right engine question.
    Nov 2011
    Ohio
    I am just had my girlfriends 2001 Taurus take a sh!t transmission wont shift so now its all about fixing her car lol
  1. need help with picking out a amp
    By mezzoni in forum Audio, Security & Visual Electronics
    Last Post: 03-09-2012, 05:10 PM
  2. picking the right amp?
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 02-22-2012, 07:42 PM
  3. Picking up a GTP
    By E90 87SS GTP in forum Introductions/Noob Questions
    Last Post: 09-26-2009, 05:22 PM
  4. Need Help Picking Car!!
    By cue244 in forum Off Topic Discussion
    Last Post: 07-03-2009, 06:14 AM
  5. Picking a car
    By robahr24 in forum General Tech Discussion
    Last Post: 01-04-2009, 03:05 PM
