Thread: 2000 GTP killing batterys
Results 1 to 4 of 4
  1. #1 2000 GTP killing batterys
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    Well like i said, 2000 gtp killing batterys like its going out of style. Iv had the car for a month now. This morning i had the car running started up just fine. i turned it off, got out then wanted to work on a vacuum line under the hood it has a leak. so i got back in and tryed starting it but the sec. i turned the key from (off) to (accessory) everything died? didnt even make it to (start). i just got in from putting in a another battery did the same thing plus, the batterys after i try are not taking a charge????? i just looked around very thing looks good. Took the wire covers off the wires leading up to the battery (+) and (-) wires. they all look good???? any ideas? i got a test light and voltage tester but not sure were to start. By the way my bad about the spelling and typing im kidda pissed about all this. Iv gotten no where sense 8:45 am. thanks
  2. #2 Re: 2000 GTP killing batterys
    St. Louis
    Def. sounds like a bad or loose cable. Remove the batt. cables and clean them, and the posts themselves. Then make sure they're nice and tight and see what you get. My 00 GT did this when the positive cable was slightly loose and corroded. And yes, it "looked" fine when I popped the hood as well.
  3. #3 Re: 2000 GTP killing batterys
    SE Level Member deangtp's Avatar
    Kansas City, MO
    My car is a 2000 as well and it seems to like the anti-corrosion battery connection gel you get from O'reilly's. It comes in a green packet and is red. Try that
  4. #4 Re: 2000 GTP killing batterys
    Mar 2012
    Alexandria, MN
    Charged the battery, got that battery clean up kit. recleaned everything twice and sprayed anti-corrosion spray its in a white bottle sprays red gose good with the engine haha. Started right up. Feel kinda foolish thats all it was but now i know. thanks
  1. Killing the stang
    By ionroller in forum Track Sessions and Kills
    Last Post: 01-26-2010, 10:07 AM
  2. killing spree
    By chad27 in forum Track Sessions and Kills
    Last Post: 05-07-2009, 06:42 AM
  3. my wife is on a killing spree!
    By stewartj1998 in forum Track Sessions and Kills
    Last Post: 04-15-2009, 10:39 PM
  4. the downpipe is KILLING me.
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 03-27-2009, 11:54 AM
  5. killing KR
    By Smokedgtp in forum Turbo
    Last Post: 05-10-2008, 05:35 PM
