Thread: Picking the right engine question.
Results 1 to 9 of 9
  1. #1 Re: Picking the right engine question.
    the easy thing to do is to just get a s/c engine and swap it, but if you cant find one, you can find a N/a block, and top swap you parts to it, heads manifolds, and the whole front of your engines pulleys and parts. but you would also want to add headers to your rebuild to let the engine breath better, being that you at now using a high compression block. and a get the pcm tuned.
  2. #2 Re: Picking the right engine question.
    Nov 2011
    Ohio
    I have headers on the car 3.4 pulley 3800performance pcm. I have a 2002 3.8lt sc found a low mile 3.8 n/a for $300
  1. need help with picking out a amp
    By mezzoni in forum Audio, Security & Visual Electronics
    Last Post: 03-09-2012, 05:10 PM
  2. picking the right amp?
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 02-22-2012, 07:42 PM
  3. Picking up a GTP
    By E90 87SS GTP in forum Introductions/Noob Questions
    Last Post: 09-26-2009, 05:22 PM
  4. Need Help Picking Car!!
    By cue244 in forum Off Topic Discussion
    Last Post: 07-03-2009, 06:14 AM
  5. Picking a car
    By robahr24 in forum General Tech Discussion
    Last Post: 01-04-2009, 03:05 PM
