Thread: 160 or 180 thermostat
Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
  1. #41 Re: 160 or 180 thermostat
    Quote Originally Posted by SnowFlake View Post
    This is a very intelligent sounding post, but when you break it down and see it for what it really is... the whole idea seems a bit over stated.
    Combustion temps can easily exceed 3000* F, and they vary greatly depending on just about everything. To say that a 15* temp difference is adding stress to the head is pretty far off base. You're talking about a piece of the engine that is just a piece of cast iron with some valves opening and shutting and how many valves have failed because of a colder thermostat? How many heads have cracked because of coolant that's 15* colder than stock?
    You're talking about a temperature gradient difference of about .005%.
    I like the big words though, Mech
    Like I said before, the temp of the oil will barely, if at all notice a 15* change in coolant temp.
    Are you sure thats the temperature of combustion?
    Are you sure coolant has that little affect on oil temp?
  2. #42 Re: 160 or 180 thermostat
    Banned
    CT
    Yes and Yes
  3. #43 Re: 160 or 180 thermostat
  4. #44
    Ohio
    yeah, cause math is hard.
    It really is :/
  5. #45 Re: 160 or 180 thermostat
    Banned
    CT
    195 - 180 = 15?
    I saw some people saying 30... so I guess math is pretty hard.
  6. #46 Re: 160 or 180 thermostat
    I can't math
    Ohio
    Why no math can you don't? Dan...
  8. #48 Re: 160 or 180 thermostat
    seven
  9. #49 Re: 160 or 180 thermostat
    Ohio
    makes sense me to does it
  10. #50 Re: 160 or 180 thermostat
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Maybe you need to ponder a little deeper. I like to hope that GM engineered critical tolerances according to their operating fit. Running a feeler gauge here and there on a room temperature component doesn't guarantee those tolerances are observed (designed) in operation. Ring clearances come to mind.
    Ohh metals and their dissimilar expansion rates.
    "3000 degree" is combustion temp, not iron temp.
    Also, a cooler than stock engine usually translates into highly increased piston ring wear.
    However, the most disturbing facet of your post is your quoted .005% temperature gradient difference. Lets continue with the 15* coolant temp difference.
    15/3000*100% = 0.5% and not 0.005%
    0.5% is something.
  11. #51 Re: 160 or 180 thermostat
    PA
    Yes and Yes
    I have been looking for years for proof of oil temps on our engines. No one seems to have it. Can you post where you read or observed that our oil temps stay above 212°F with a 180°F t-stat?
    2001 GSE
  1. Thermostat
    By jaydasparkz in forum Engine
    Last Post: 12-10-2011, 10:49 PM
  2. bad thermostat?
    By jwhite85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2011, 12:22 PM
  3. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
  4. Thermostat!????
    By fratzke7 in forum General Tech Discussion
    Last Post: 03-16-2009, 11:35 AM
  5. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
