Thread: Issues swapping 2007 l32 into 2000 GTP???????
Results 1 to 4 of 4
  1. #1 Issues swapping 2007 l32 into 2000 GTP???????
    Nov 2011
    S Fla
    I know everything bolts up with the 04 swaps, but did they make any changes between 04 and 07 that could cause me problems?
    Will my injectors fit the 07 heads? Will the 07 flywheel bolt up to my converter, and will the bellhousing bolt to the block? Will my exhaust manifolds bolt up to it?
    I know I'll need my fuel rails, possible a new coolant sensor, and a brass nipple behind (or in front of???) the throttle blade, an extender for the maf (I think it's the maf that needs the extender) and the TB adapter. I'll want, but not NEED a tune to get the most out of it. Can you think of anything I've missed?
    Black 2000 GTP. Replaced plugs, wires, maf, IAC, tires, tie rod ends, and s/c oil. Lifetime alignment. No mods yet, just got it. Straightening everything out first. 128,xxx miles
  2. #2 Re: Issues swapping 2007 l32 into 2000 GTP???????
    utah
    the l32 has different injectors then the l67
  3. #3 Re: Issues swapping 2007 l32 into 2000 GTP???????
    besides the throttle body and fueling stuff, the rest bolts up just the same.
  4. #4 Re: Issues swapping 2007 l32 into 2000 GTP???????
    Nope..it's all just like you said.
    Exhaust bolt up is the same. Meaning the heads are done the same.
    Flex.. is dual drilled.. will work great
    Bell housing to block is all the same
    Do the mod for the PCV
    You can use the evap that comes with the new motor. The adapter and stock TB allow enough clearance
    Cap the hole on the TB where the evap used to connect for vacuum.
    Need any pics, holler. I just Gen V'd my setup.
  1. Replies: 0
    Last Post: 02-18-2012, 01:47 PM
  2. 2000 gtp issues, concerns.
    By 3CLiPSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2011, 04:50 PM
  3. 2007 Grand Prix trans has issues shifting
    By Das Pilot in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-11-2011, 04:04 PM
  4. 2000 gp gt blower issues...any help?
    By circa09 in forum General Tech Discussion
    Last Post: 04-20-2011, 01:37 PM
  5. dexron 6 issues in a 2000 GTP
    By calvin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2011, 08:53 AM
