Update:
Replaced Valve Cover Gaskets
SD Headers Installed
NGK Spark Plugs Installed
Replaced Fuel Filter
New Maf Installed.
Replaced Vacuum Lines
Aeroforce Scan Gauge (:
Before:
Maf Low Signal
Cylinder Misfire 1
Random Cylinder Misfire
Now:
Maf Low Signal
Friend of mine on here said to check the grounds on the car, get them cleaned up, lil sandpaper here and there, if not, bad wiring.
I have a new maf on there and still the code comes up. Power is there, it hesitates on shifting though, it will accelerate, get cut off, accelerate some more cut off, let off the gas, change gear. No codes from the transmission though.
Couple days ago i put some lucas fuel injector prior to a 160 mile drive, on the way back, codes went away and it shifted and drove like it supposed to, vroom! And this is with the old maf installed. next day, codes still werent showing up, later on after work, warm day, turned on the car and the codes appeared and it drove so bad, and then here i am now, new maf and aeroforce installed. I see no kr at all, even when i gas it hard, but if i gas it hard from a stop, it hesitates before shifting and i got about almost7 kr. but thats it. if i gas it from 30 or 40, i get as much as 1 kr. I cant figure out the problem, im pretty sure the maf is killin my car though, i get no readings from the aeroforce for the maf. Bad wiring for sure, idk where to start? what other things should i do? thanks.
Car is a moneypit. well, almost done saving up for an evo, my second one (:
