Thread: Update on GTP, cant figure out problem
Results 1 to 20 of 24
  1. #1 Update on GTP, cant figure out problem
    Jul 2011
    Los Angeles
    Update:
    Replaced Valve Cover Gaskets
    SD Headers Installed
    NGK Spark Plugs Installed
    Replaced Fuel Filter
    New Maf Installed.
    Replaced Vacuum Lines
    Aeroforce Scan Gauge (:
    Before:
    Maf Low Signal
    Cylinder Misfire 1
    Random Cylinder Misfire
    Now:
    Maf Low Signal
    Friend of mine on here said to check the grounds on the car, get them cleaned up, lil sandpaper here and there, if not, bad wiring.
    I have a new maf on there and still the code comes up. Power is there, it hesitates on shifting though, it will accelerate, get cut off, accelerate some more cut off, let off the gas, change gear. No codes from the transmission though.
    Couple days ago i put some lucas fuel injector prior to a 160 mile drive, on the way back, codes went away and it shifted and drove like it supposed to, vroom! And this is with the old maf installed. next day, codes still werent showing up, later on after work, warm day, turned on the car and the codes appeared and it drove so bad, and then here i am now, new maf and aeroforce installed. I see no kr at all, even when i gas it hard, but if i gas it hard from a stop, it hesitates before shifting and i got about almost7 kr. but thats it. if i gas it from 30 or 40, i get as much as 1 kr. I cant figure out the problem, im pretty sure the maf is killin my car though, i get no readings from the aeroforce for the maf. Bad wiring for sure, idk where to start? what other things should i do? thanks.
    Car is a moneypit. well, almost done saving up for an evo, my second one (:
  2. #2 Re: Update on GTP, cant figure out problem
    Omaha, NE
    Is the "new maf" a refirb?
  3. #3 Re: Update on GTP, cant figure out problem
    Jul 2011
    Los Angeles
    no its not, brand new from the auto parts store that my shop orders from. im gonna stick the old one in, and if i get any readings from my aeroforce, then its bad and i better get a refund, they aint cheap.
  4. #4 Re: Update on GTP, cant figure out problem
    Vancouver, WA
    How does it drive with the Mar unplugged?
    Slowest 'Cooled Gen V ever
  5. #5 Re: Update on GTP, cant figure out problem
    Jul 2011
    Los Angeles
    i have never tried it, but to my understanding, since the scan gauge gets no readings, yet im guessing the car knows its plugged in?
    It idles great, doesnt shut off, power is there. i will try tomorrow with it unplugged, if it goes better unplugged then my new maf isnt working properly. or back to where im thinking, bad wire somewhere.
  6. #6 Re: Update on GTP, cant figure out problem
    Check your fuse it's the one that data ign 1 or something like that under the hood. Then check your voltage at the maf.
    Jul 2011
    Los Angeles
    I checked the fuse, it's fine. I plugged a meter to it, getting no power or any ground but the PCM is talking to it.
  8. #8 Re: Update on GTP, cant figure out problem
    The middle one is the ground the yellow wire should get around 5ish volts and the pink one should get around 12 ish volts. I just had to track down my maf problem. If you aren't getting any voltage to the maf run the wiring and see if you can find any spots were it's cracked or brittle.
    Jul 2011
    Los Angeles
    How do I run the wiring? In gonna check the grounds first, all my fuses are good
  10. #10 Re: Update on GTP, cant figure out problem
    Check how it looks at the connection to the maf and follow the wire as far as you can and make sure it all looks good. You checked to see if it's getting voltage at the plug right?
    Jul 2011
    Los Angeles
    Yeah that's where I checked, so I have to unwrap all the wiring, to follow it around? I'm looking for a schematic as well for the maf
  12. #12 Re: Update on GTP, cant figure out problem
    Looks like that maybe what you have to do. I ended up have voltage to my maf and had to replace the sensor itself.
    Jul 2011
    Los Angeles
    I replaced the sensor and the code is still there
  14. #14 Re: Update on GTP, cant figure out problem
    Thats why i said to look at the wiring you have to have a short somewhere.
  15. #15 Re: Update on GTP, cant figure out problem
    Jul 2011
    Los Angeles
    okay, i pulled out the meter again to get readings. with the maf unplugged, i get 5 volts and 12 volts, with it plugged, i dont get any. how weird is that?! really tired, but im gonna recheck everything tomorrow morning at work.
  16. #16 Re: Update on GTP, cant figure out problem
    possible you got a bad sensor.
    Bunnell, FL
    Mine is and.throws.that codewhy?
    Android Fire
    I'm a Sex Offender
  18. #18 Re: Update on GTP, cant figure out problem
    Jul 2011
    Los Angeles
    right, i could have a bad sensor, but this a brand new sensor, its very frustrating. ima throw the old one back on and see what i get. I wanna make sure all my wires are good and my ground is too, this is a project just to figure this out.
  19. #19 Re: Update on GTP, cant figure out problem
    Feb 2009
    flintnasty MI
    You shouldnt get 5 volts anywhere.l.. the pink wire does 12volts, and the ground is ground.. tthe other wire goes back to the pcm after the maf processes a digital signal, so there is no voltage measurabled leaving on that line.
  20. #20 Re: Update on GTP, cant figure out problem
    Mine had 4.5 volts at the yellow wire key on car not running.
  1. Transmission problem Update: post rebuild issues
    By IffyG in forum General Tech Discussion
    Last Post: 07-06-2012, 12:13 PM
  2. Engine squeal, vacuum related *UPDATE* Problem Solved (see last post)
    By 98L36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2011, 03:21 PM
  3. help me figure out my problem
    By Accident in forum General Tech Discussion
    Last Post: 04-24-2011, 06:39 PM
  4. Exhaust problem **UPDATE**
    By GPGT99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-19-2009, 08:14 PM
  5. Problem cant figure it out!! HELP!! LONG!
    By iwinagn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2008, 07:19 PM
