Thread: p0401 and p0442 code
Results 1 to 20 of 22
  1. #1 p0401 and p0442 code
    gardner,mass
    Ok so first thing i was getting only the p0442 code when i got the car so my first thought was gas cap i replaced it and reset the light and it came back on. I read the codes again and i had that same code but then the p0171 code came up i cleaned my maf egr and pcv and reset the codes. Ive also replaced the spark plugs wires fuel filter changed oil tranny fluid filter oil pan thermistat coolant sc oil and made my own air intake with a larg spectre filter and pvc pipe and now my code came back up i had it read again after the p0171 code had gone away it came back up[ with the autozone scanner. so my initial thought was has to be maf. I ordered the maf and ill have it on monday but for **** and giggles i read the code tonight with my machine at work(much higher grade machine than autozone) and instead of the p0171 code i got p0401 and th p0442 code again and also some traction control code im really not worried about. Im stuck on this and need to get a sticker. Any help would be greatly appreciated.
    2000 pontiac gtp
  2. #2 Re: p0401 and p0442 code
    What car do you have? What do those codes mean? I'm to lazy to look it up for you.
  3. #3 Re: p0401 and p0442 code
    gardner,mass
    Another thought my mpg is absolute crap. Im getting 16-17 according to the gauge. I know this can be a little off but shouldnt i be getting atleast 20-23 mpg?
  4. #4 Re: p0401 and p0442 code
    depends on your driving style and where you drive. I get 24ish driving back and forth to work.
  5. #5 Re: p0401 and p0442 code
    gardner,mass
    the highest ive got was 18 when i was going 55-65 on highway coming from work basicly not pressing the throttle at all
  6. #6 Re: p0401 and p0442 code
    isn't the 401 code for the egr or something?
  7. #7 Re: p0401 and p0442 code
    gardner,mass
    yes and the 442 is typicly gas cap and 171 is bank 1 lean so could be vacuum leak maf o2 exaust leak or various other things
  8. #8 Re: p0401 and p0442 code
    vacuum leak around the egr? That's where i would start. Check all your vacuum lines while your at it. If the egr is messed up and your running really lean it'll kill your gas mileage.
  9. #9 Re: p0401 and p0442 code
    also your maf probably isn't bad.
  10. #10 Re: p0401 and p0442 code
    gardner,mass
    ya im very confused on this ive replaced the egr gasket and cleaned it up and sprayed all over the vacuum lines with carb cleaner with no results, im thinking smoke test is my only option to narrow things down
  11. #11 Re: p0401 and p0442 code
    When my maf went bad last week i got the 102 code. Your egr could just be bad and be stuck open and it'll cause you problems.
  12. #12 Re: p0401 and p0442 code
    gardner,mass
    is there a gaurenteed way to check this?
  13. #13 Re: p0401 and p0442 code
    I'm pretty sure there is a way to check with an expensive scanner to make it open and close manually and look at it. I wouldn't go throwing parts at it and hoping you fix it.
  14. #14 Re: p0401 and p0442 code
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Pull the egr hose that goes in the manifold. It will have a crack in it. This will throw the p0171
    You have to remove it and look at the edge. Carb cleaner will not find this.
    1997 Red GTP 182000 miles stock
  15. #15 Re: p0401 and p0442 code
    gardner,mass
    Quote Originally Posted by GTP in RTP View Post
    This was my exact thought are there gaskets on that hose?
  16. #16 Re: p0401 and p0442 code
    GTP Level Member
    Oct 2011
    Raleigh, NC
    no, just flared ends that crack.
  17. #17 Re: p0401 and p0442 code
    GTP Level Member
    Oct 2011
    Raleigh, NC
    one other thing to check is the screen on the tb. Is it there or missing, sometimes if it is removed idle will be rough.
  18. #18 Re: p0401 and p0442 code
    gardner,mass
    Idle isn't rough but that screen does have a few breaks and indents in it
  19. #19 Re: p0401 and p0442 code
    GTP Level Member
    Oct 2011
    Raleigh, NC
    The screen provides laminar ( smooth ) airflow across the MAF, helps the maf to be more accurate. Get one at the jy next trip.
  20. #20 Re: p0401 and p0442 code
    gardner,mass
    To arrow morning ima check out that hose replace that screen and was thinking about ripping th egr off this gp with only 28k on it any idea what an egr usually goes for in th jy?
  1. Need help fixing EGR code P0401!!!
    By grprx01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2022, 06:48 PM
  2. P0401 code now...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2011, 02:21 PM
  3. P0401 Code
    By screechingdemon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2011, 09:24 AM
  4. code P0401
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 01:30 PM
  5. P0442 trouble code?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:33 AM
