Thread: Replacing LIM and UIM gaskets, 2004 GTP
Results 1 to 2 of 2
  1. #1 Replacing LIM and UIM gaskets, 2004 GTP
    Jan 2012
    St. Cloud, MN
    Hello,
    Im going to be replacing the lower and upper intake manifold gaskets soon, They are leaking coolant everywhere. My question is what else would be a good idea to replace while I have the intake manifold and supercharger off.
  2. #2 Re: Replacing LIM and UIM gaskets, 2004 GTP
    Hopefully you didn't see Brians unreasonable answer before I removed it.
    Gaskets/things to do while you are there.
    New set of coolant elbows (Dorman 47065)
    Fresh TB gasket
    Check/replace any old/bad vacuum lines
    New fuel injector o-rings (es70599 need 3 packs)
    If your valve covers are leaking, it's also much easier to do them with everything off.
  1. Replacing Lim and up gaskets.
    By 90oddz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2010, 03:47 PM
  2. replacing intake gaskets?
    By stretch5363 in forum Shops and Community Heroes
    Last Post: 01-13-2010, 04:51 PM
  3. Replacing head gaskets
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 12:11 AM
  4. Suggestions while replacing intake gaskets
    By 918GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 09:18 PM
  5. replacing LIM gaskets. HELP!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 06:22 PM
