Thread: Replacing head gaskets
Results 1 to 10 of 10
  1. #1 Replacing head gaskets
    SE Level Member Spazztic2003's Avatar
    Oxford, MI
    Trying to tear the heads off on my car. Do I need a special tool to get to the bolts on the underside of the stock exhaust manifold? Seems that there's no way I can reach them with the runners being directly over them.
    A fan of Pontiac and their cars since my birth in Pontiac.
    Proud owner of the world's worst '98 GTP, falling apart in every way!
  2. #2 Re: Replacing head gaskets
    Donating Users kfish's Avatar
    Ohio
    i took my manifolds off
  3. #3 Re: Replacing head gaskets
    God forbid you have to use a wrench.
  4. #4 Re: Replacing head gaskets
    Oxford, MI
    some of us have larger-than-normal wrenches because our local hardware stores fail. :P
    is that it? i just need a smaller wrench to reach those two bolts?
  5. #5 Re: Replacing head gaskets
    Apr 2009
    stockton ca
    take the mani's off would be the easiest way
  6. #6 Re: Replacing head gaskets
    You should find that the exhaust manifolds need to come off and if the two end studs stay in the head, those should be removed as well. Then you will have good access to all the bolts.
  7. #7 Re: Replacing head gaskets
    Oxford, MI
    i'm trying to remove the manifold. that's what i'm saying. there are four bolts on the bottom side of it that are bolting it to the heads or the block, not sure which, but two or three i can't get.
    i got the bolt farthest to the right. just had to take off the engine mount bracket to get to it. no exhaust runners are over that bolt, so it was easy to take off with a ratchet.
    the rest of the bolts are directly under each runner. with a wrench i have maybe an inch of room til the wrench hits one of the runner pipes, so i don't have very much room to get a good tugging angle on to break the bolt.
    did you guys access these bolts from underneath the car or do i just need a ratchet wrench or what?
  8. #8 Re: Replacing head gaskets
    Oxford, MI
    i guess i could just take a picture too. heh
  9. #9 Re: Replacing head gaskets
    PA
    There should not be any problem with getting a socket onto the bolt/stud of the exhaust manifolds.
    If you are trying to remove the head bolts, you need to remove the exhaust manifold first.
    2001 GSE
  10. #10 Re: Replacing head gaskets
    Oxford, MI
    ah i see now. alrighty, thanks!
  1. Copper Head Gaskets
    By bigdawg15005 in forum General Tech Discussion
    Last Post: 10-15-2009, 08:34 PM
  2. Suggestions while replacing intake gaskets
    By 918GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 09:18 PM
  3. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
  4. replacing LIM gaskets. HELP!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 06:22 PM
  5. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
