Thread: Replacing Lim and up gaskets.
Results 1 to 2 of 2
  1. #1 Replacing Lim and up gaskets.
    Newfoundland
    I noticed my Front valve cover gasket is leaking and when i looked down around the motor i notice that around the LIM its wet(oil) but not leaking out, more or less just seeping out. Im going to price all the gaskets from the LIM up tomorrow. I was wondering if theres anything i should be careful of removing or anything on the motor i should replace at this time, I also noticed my car burns oil, and when i checked the oil cap there was a bit of white sludge on it, so i'm assuming that theres some coolant leaking in there as well. Im not to familiar with these motors so any help would be greatly appreciated.
    Also does anyone know how much the gaskets should roughly cost? Canadian?
    Thanks
    Kyle.
  2. #2 Re: Replacing Lim and up gaskets.
    Apr 2009
    stockton ca
    you will need 2x quarts cheap oil to wash down the valleys once its all taken apart
    oil filter and oil for a change after works done
    coolant id suggest a full flush and go with green coolant if it isnt alreaady
    more then likely you will break the coolant elbows so you will want to replace those
    injector orings 12x
    valve cover gaskets front and back and gromets
    aluminum lim gaskets , uim gasket, tb gasket,
    if your tstat has miles on it nows a good time to swap same with rad hoses
    steelwool or synthetic steel wool and a gasket scraper aswell as a few cans of brake clean
    i would also use some egine degreaser and wash down the engine before you start tearing it down
  1. replacing intake gaskets?
    By stretch5363 in forum Shops and Community Heroes
    Last Post: 01-13-2010, 04:51 PM
  2. LIM Gaskets
    By jmac in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 02:12 PM
  3. Replacing head gaskets
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 12:11 AM
  4. Suggestions while replacing intake gaskets
    By 918GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 09:18 PM
  5. replacing LIM gaskets. HELP!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 06:22 PM
