Thread: Should my valvetrain be ok for an S1X cam?
Page 4 of 4 FirstFirst ... 234
Results 61 to 66 of 66
  1. #61 Re: Should my valvetrain be ok for an S1X cam?
    Feb 2009
    flintnasty MI
    Also a stock rocker will put out about .030 deflection on a LS6 spring, and about .025 on a 105 spring.... which puts a .600 lift back around the 570
  2. #62 Re: Should my valvetrain be ok for an S1X cam?
    I didnt put enough time into the rig to measure which one gave more or less lift on a xp cam... the cam/lifter dynamic is one that is hard to emulate on a bench.
    Oh, so it is just a guess.
    Cool.
  3. #63 Re: Should my valvetrain be ok for an S1X cam?
    Feb 2009
    flintnasty MI
    No, my precision and lack of ability to test vs a cam/rocker/pushrod was what was limiting me from making specific factual observations. It is not easy to measure things like this in precision +-.005, and frankly it was not needed for what I was trying to prove. all I needed to know was that a 1.6 roller had SIGNIFICANTLY less peak lift than a stock rocker, and that a 1.8 rocker had similar peak lift to a stock rocker.
  4. #64 Re: Should my valvetrain be ok for an S1X cam?
    I've read your posts,
    So that means everyone has been doing it wrong all these years milling valve guides when running ANYTHING more than .550" lift.
    Guess so.
  5. #65 Re: Should my valvetrain be ok for an S1X cam?
    GTX Level Member crbquist's Avatar
    Massachusetts
    Soooo... 1.6 stock rockers are better than 1.6 rollers??? Just doesn't seem right to me....
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  6. #66 Re: Should my valvetrain be ok for an S1X cam?
    Massachusetts
    1.9 rollers are a very small upgrade in peak lift over stock on a XP or s1x. 1.8s are considered a nearly insignificant upgrade over stock rockers in lift.
    You probably do not need clearanced guides with 1.9 rollers on a xp or S1x any more than you need it with stock rockers.
    I just can't see how 1.9 rrs would work with an s1x or xp, especially if we are referring to stock heads. Maybe with stg3 ported heads and 130# springs I can see running 1.8s, but seriously 1.9s??
  1. Valvetrain noise?
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:54 PM
  2. HELP PLEASE valvetrain bolts
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 01-14-2011, 05:42 PM
  3. Valvetrain Questions
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 07:55 AM
  4. Can valvetrain noise cause KR?
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2009, 09:02 PM
  5. Springless Valvetrain
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-21-2008, 01:10 PM
