Thread: Gen V with L67 throttlebody need vacuum routing pics
Results 1 to 3 of 3
  1. #1 Gen V with L67 throttlebody need vacuum routing pics
    GTP Level Member buickman104's Avatar
    NYC
    I swapped a gen V supercharger into my L67 long block. Car is getting oddly high partial throttle KR, but at WOT only getting 2-3 degrees of KR. My fuel economy has taken a serious hit used to get 13 city/32 highway now getting 11 city/ 25 highway. I am running the evap that is built into the gen V, but I have a check engine code for it. Anyone that has a gen v with a stock l67 throttlebody please post pictures to get an idea of how you routed your vacuum lines.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Gen V with L67 throttlebody need vacuum routing pics
    Charles City, IA
    My evap is caped off, then I just ran a vac line from the pvc nipple to the throttle body adapter.
    SMGPFC Two Nipple General
  3. #3 Re: Gen V with L67 throttlebody need vacuum routing pics
    NYC
    My tb adapter has nothing i can plug into. I drilled and tapped a nipple into the throttlebody itself and have the pcv going into that.
  1. L67 vacuum routing HELP!
    By thunder71173 in forum General Tech Discussion
    Last Post: 04-02-2011, 06:33 PM
  2. Vacuum Part Identification (pics)
    By SlowNA06 in forum General Tech Discussion
    Last Post: 07-22-2010, 11:18 PM
  3. looking for a vacuum line routing guide
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2010, 12:02 PM
  4. ZZP throttlebody
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2009, 10:20 PM
