Thread: Can valvetrain noise cause KR?
Results 1 to 8 of 8
  1. #1 Can valvetrain noise cause KR?
    SE Level Member Infinity9999's Avatar
    Dec 2008
    Brookfield, WI
    Trying to tune, and I'm just getting obscene amounts of KR for the mods that I have (I think, at least). So I'm wondering if the ticking that I seem to have from my rockers is loud enough to make my knock sensor think that I have knock. It only happens under load with the s/c belt on and it really doesn't change whether I'm on a 3.6 or a 3.4 (I've been on the 3.6 for a while now). I'm actually getting a VS cam installed next week and will be going back to my stock rockers, so I'll probably find out then. Just wondering if there's anything else I should have them look for while the engine is torn apart. It just really seems that my KR is mechanical and not just fueling or something tunable.
    04 Black GTP Comp G
    Mods: 3.2 pulley, SSIC, Wizair, AL104s, OBX headers, VS cam, 105# springs, 42# injectors, PowrTuner
  2. #2 Re: Can valvetrain noise cause KR?
    rockers wouldnt set of your knock sensors.
    it REALLY depends on how your tune looks for anyone to tell anything.
  3. #3 Re: Can valvetrain noise cause KR?
    Dec 2008
    Brookfield, WI
    It's actually a pretty conservative tune. Mainly stock since I got the 04. Started with the basic Webracin tune to eliminate some of the TQ management stuff. Couple tweaks to PE/AFR/RPM/Time as well as a few MAF tunes. I had 42# injectors in there, but went back to stock, along with bringing the IFR table back to stock. I don't have a WB (I know, I know), but my NB O2s have always seemed to stay in the 930-940 range. And it's not burst KR or shift KR either. It's consistent and only when I hit a higher TPS% (i.e. I can run at 60% TPS in boost without KR, but if I get over 90% then it's all over the place).
    04 Black GTP Comp G
  4. #4 Re: Can valvetrain noise cause KR?
    it sounds like you havent pushed the thresholds of the torque limits as far as they need to be. once i pushed them past what my car was making (to save the transmission) my knock was down to 1* from 10* when we started.
  5. #5 Re: Can valvetrain noise cause KR?
    Dec 2008
    Brookfield, WI
    That could very well be. With different gearing in the 04 than in my old 97 and whatnot, I'm not sure exactly what's different. A lot of what I've been setting things to came from my 97 bins just as a starting point.
    04 Black GTP Comp G
  6. #6 Re: Can valvetrain noise cause KR?
    ooh, nice. didnt know you got a new car. good luck with that one.
  7. #7 Re: Can valvetrain noise cause KR?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    I havent heard valvetrain noise being a promblem on the 3800. IIR LS1s have this promblem sometimes. what type of tuner do you have?
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  8. #8 Re: Can valvetrain noise cause KR?
    Dec 2008
    Brookfield, WI
    Powrtuner. I actually had my 97 tuned pretty well. There's just some differences in tables and views in the 04 bin that I'm not exactly sure if they work the same way (with support tables I can't see, etc). Like I said, I'm not really doing much more in the way of tuning until I get my cam installed next Monday, so we'll see what happens to the noise when the stock rockers go back in. I'm really kind of hoping that I can go back to the 3.4 and maybe even the 3.2 if it's tunable once that cam is in there. We'll see...with winter coming, I'll probably leave things conservative for now.
    04 Black GTP Comp G
  1. This noise
    By pontiackid in forum General Tech Discussion
    Last Post: 06-11-2009, 11:41 AM
  2. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
  3. Springless Valvetrain
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-21-2008, 01:10 PM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
