Thread: Valvetrain noise?
Results 1 to 18 of 18
  1. #1 Valvetrain noise?
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    I have a tapping sound coming from the top end in the valvetrain, it is what sounds like a bad lifter or loose rocker arm. The valvetrain is all original nothing in it was replaced when i rebuilt the engine that had 116,000 miles on it except for the 1.9 modded rockers i put in, the cam looked fine when it all went together and the car ran great and was quiet, now that i got about 5,000 miles on it, its making this noise. first thing i did is put a new set of lifters in and it was still there just like before. then i checked over the valve springs for cracks and couldnt find any, but i found one i could just spin around with my hand, so i figured it was weak and put comp 105 springs in along with the right retainers and locks and also new comp push rods. this is where things get strange, it was completely quiet again, i drove it about 15 miles to work sounded good, and on the way home it started again and is now just as loud as it was, and whats weird about it is sometimes as i drive it it goes away for a few miles then comes back, and when its tapping it reads it as knock and pulls about 14 degrees timing out, im lost and have no idea what it could be other than maybe a cam lobe worn even though rollers on original lifters were fine? or i got a new lifter thats defective but i doubt it because the sound is in the same spot. Used a friends scope and put it down near the middle of the v on the drivers side and thats where you can really hear something like the lifter just slapping on the cam. Oil pressure is 70 pounds at 1800 and compression is good and even on all cylinders, and i did change the oil and it doesnt appear to have anything in it. If anyone has any ideas for me or have ever heard of a cam in these being bad, anything would be appreciated.
  2. #2 Re: Valvetrain noise?
    A buddy had a similiar issue when a cam bearing spun. It's not common and what happens is oil is cut off to those lifters and they can't pump up.
    How did the oiling look? Any dryness or oddness about it?
  3. #3 Re: Valvetrain noise?
    Jan 2009
    State College PA
    oil is coming out all the pushrods, doesnt shoot out and make a mess like i would think it would but just kinda runs out a little
  4. #4 Re: Valvetrain noise?
    that's about all it should be. OR rods or regular rods?
    tough to think you got another set of bad lifters. Odd about that spring being weak/loose.
  5. #5 Re: Valvetrain noise?
    Jan 2009
    State College PA
    regular comp hi tech rods not restricted
  6. #6 Re: Valvetrain noise?
    Jan 2009
    State College PA
    and if a cam bearing is spun what should be done with the block?
  7. #7 Re: Valvetrain noise?
  8. #8 Re: Valvetrain noise?
    All dots should be at 0's... like the Suby guy said.
  9. #9 Re: Valvetrain noise?
    Jan 2009
    State College PA
    Ok thanks, see if I can get this money pit into the 12's and scatter the tranny
  10. #10 Re: Valvetrain noise?
    Jan 2009
    State College PA
    well, i just got the engine back in the car with new cam bearings and my new xp cam and wow same noise in the same spot and just as loud as it was and that is also with the known good lifters put in the back, so im at a loss and going to get a adjustable pushrod and move it around until i get the noise out of it and then get one different length one, I have no idea what else to try to do?
  11. #11 Re: Valvetrain noise?
    Jan 2009
    State College PA
    Measured and figured out that i have .100 of preload, i was told there should not be over .060 of preload, does this sound like it could be my problem? Thinking of trying 7.000 pushrods instead of the 7.050 ones i have now
  12. #12 Re: Valvetrain noise?
    SE Level Member sf49ers76's Avatar
    Jun 2011
    IL
    Sounds to me like you have a valve that has mushroomed and is not the same length as the rest.
    take all rockers off and put a straight edge across as many of the tops of the valves as you can and see if the one making the noise is longer than the rest.
    that is why the measurement you had is out of specs.
  13. #13 Re: Valvetrain noise?
    Jan 2009
    State College PA
    cant really do that with the springs still on can i? i would have to take the heads off
  14. #14 Re: Valvetrain noise?
    Jun 2011
    IL
    yeah you should be able to. Once the rockers are out of the way you can probably just visibly see if the valve stem appears to be slightly higher than the rest of them.
    Probably can get away with just only removing the valve cover to check it.
    and if you feel you need to remove the spring you can do that with minimal work as well.
  1. HELP PLEASE valvetrain bolts
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 01-14-2011, 05:42 PM
  2. What supporting valvetrain mods for cam?
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2010, 11:54 PM
  3. Valvetrain Questions
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 07:55 AM
  4. Can valvetrain noise cause KR?
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2009, 09:02 PM
  5. Springless Valvetrain
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-21-2008, 01:10 PM
