Thread: Engine wont start
Results 1 to 20 of 110
  1. #1 Re: Engine wont start
    SE Level Member Hixc's Avatar
    Lawrence MA
    i replaced the key and the harmonic balancer looks good to reuse still. it was 180* backwards. i put it all back together and found i had a major coolant leak around the crankshaft sensor..... ugh! now i have to take it all apart again, and figure out what i did wrong
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  2. #2 Re: Engine wont start
    Lawrence MA
    fixed coolant leak. turns out i forgot to put a bolt in. car starts up and runs! best of all there is no knocking noises coming from the engine, sounds mechanically sound. i will post a vid asap of it.. it does need a driver axle seal, coolant temp sensor wiring, and a really good tune up. i have not tried WOT yet, but i did open it up to about 50% and i read 1-9*knock. ive hit that once and been babying it ever sense. dont need to blow another lower end! lol
  3. #3 Re: Engine wont start
    Sit balancer on crank. Turn and push until key engages.
    BTW.. I was doing springs this weekend and wanted to try putting the lock in upside down.. just couldn't actually get myself to do it..
  4. #4 Re: Engine wont start
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    We are fighting, sir.
  5. #5 Re: Engine wont start
    Start driving..it's gonna take you a couple of days
  1. wont start
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 01:56 AM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. rough engine then wont start
    By RyanL in forum General Tech Discussion
    Last Post: 06-06-2010, 03:32 AM
  4. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
