Thread: Shuttering on hard acceleration
Results 1 to 12 of 12
  1. #1 Shuttering on hard acceleration
    WI
    I'm getting pretty nasty shuttering on hard acceleration. Also I'm fouling plugs pretty regularly. I've tried stock, colder, E3, etc. Same results. My Air fuel ratio is 14.7 - Is that too high?? My inj pulse seemed to be ok. MAF reading was roughly 5.15 2300-2600 area. KR of 0
    I've got CAI, ported manifolds, ubend delete, resinator and muffler delete(If that is considered mod lol), 180Tstat, 3.5pulley drop, MSD Wires and coils(Wish I still had the stock cause I heard MSD coils are worse).
    Thanks in advance for ANY advice.
    1997 GTP 102k - Near stock with loads of new parts
  2. #2 Re: Shuttering on hard acceleration
    WI
    Also fuel pressure was 45-55 consistant. I also done a compression test to each cylinder - each one was roughly 115-125 and according to the dealer anything about 100 is good.
  3. #3 Re: Shuttering on hard acceleration
    WI
    Anybody? Anything?
  4. #4 Re: Shuttering on hard acceleration
    WI
    Also, I was just informed by someone to try the traction control??? How do I even turn that off on 97 gtp??
  5. #5 Re: Shuttering on hard acceleration
    Laurel MD
    Are all your engine mounts poly or the rubber? If it's still rubber, maybe the engine is just torquing over and the trans dipstick is wanging against the firewall.
  6. #6 Re: Shuttering on hard acceleration
    SE Level Member Enzo354's Avatar
    USA
    Could it be a vacuum leak?
  7. #7 Re: Shuttering on hard acceleration
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    Have you checked ignition coils and ignition control module?
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  8. #8 Re: Shuttering on hard acceleration
    SE Level Member Phyrstorm's Avatar
    Jun 2010
    Sioux Falls, sD
    When I had this happen last summer found one of the coils was shot but it was only noticeable during hard acceleration. Are you getting a check engine light at all?
  9. #9 Re: Shuttering on hard acceleration
    Laurel MD
    In the same line as the ignition coils, maybe your plug wires aren't making good contact.
  10. #10 Re: Shuttering on hard acceleration
    WI
    I haven't changed the coils but I have been told to junk the msds and put stock back on by quite a few people. And no they're still the poly mounts on the engine. I pulled the abs ign fuse today and it seemed to help a bit aqctually. I did get a ses light and code that popped up was cylinde3r 4 misfire. Put new plugs and msd wires. Still get it on hard acceleration. That's why I thought compression check but luckily it turned out fine. And I thought when coils went it would set off 2 cylinders to misfire
  11. #11 Re: Shuttering on hard acceleration
    PA
    Quote Originally Posted by Pshnmeawy View Post
    Check over your plugs and wires really well. Make sure you have them run from the correct coils to the correct plugs. And yes, the MSD coils are not doing you any favors.
    As for traction control in your 97, there is no way to "turn it off". It can only be deprogrammed out of the computer.
    2001 GSE
  12. #12 Re: Shuttering on hard acceleration
    GT Level Member RegalGS98s's Avatar
    NJ
    Your plugs are fouling, are they all fouling, or just ones from certain cylinders? Like Zef said, you may have the spark plug wires running to the wrong coil packs. If it's cylinders 3 and 4 you're receiving misfires from, those 2 may have the wires switched. And like others said, haven't heard good things about MSD coilpacks. Some though few, have run them with no problems.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  1. Engine stuttering on hard acceleration
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2011, 07:09 PM
  2. Lock up TC engages hard on acceleration
    By dearmond in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-30-2009, 12:01 AM
  3. Car "shuttering" under moderate boost?
    By CDoran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 09:25 PM
  4. 2000 GTP miss on hard acceleration
    By gtp2000 in forum General Tech Discussion
    Last Post: 07-26-2009, 01:31 PM
  5. 2000 GTP miss on hard acceleration
    By gtp2000 in forum Introductions/Noob Questions
    Last Post: 07-26-2009, 01:06 PM
