Thread: 98 Grand Prix GTP Possible Bad Ignition Switch
Results 1 to 4 of 4
  1. #1 98 Grand Prix GTP Possible Bad Ignition Switch
    El Cajon
    The problem is I can go to start my car and nothing happens. I can try to start it and sometimes it takes about Five minutes for it to turn over and then its fine for awhile then I let it sit for an hour or so and when I go out to start it again nothing happens. I here the relay click behind the glove box but the car wont even turn over and then after about 5 to ten minutes of turning the ignition key it just starts and when I stop the car it wont start for awhile again. I think its the ignition switch but thats an expensive part to change out if Im wrong. I need help.
  2. #2 Re: 98 Grand Prix GTP Possible Bad Ignition Switch
    St. Louis
    Check both the battery cables and terminals to be sure they are clean of corrosion and are tight. I've seen corroded terminals cause this before. And best of all its free!
  3. #3 Re: 98 Grand Prix GTP Possible Bad Ignition Switch
    Vancouver, WA
    Sounds exactly like when my ignition switch went bad. Replace it and be done with it.
    Slowest 'Cooled Gen V ever
  4. #4 Re: 98 Grand Prix GTP Possible Bad Ignition Switch
    El Cajon
    Thanks to all that replied. I replaced the Ignition Switch and it works fine now. This has been a problem for about two weeks now and I am glad that this problem has been corrected. Again Thanks!!!!!!!
  1. 06 grand prix ignition
    By chileman in forum General Tech Discussion
    Last Post: 09-19-2010, 05:56 PM
  2. 2001 Grand Prix ignition switch position
    By davejt in forum General Tech Discussion
    Last Post: 06-15-2010, 11:07 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. 98 grand prix se key stuck in ignition
    By Squishy in forum General Tech Discussion
    Last Post: 11-25-2009, 01:45 AM
  5. 2000 Grand Prix Ignition Switch
    By grneyes908 in forum General Tech Discussion
    Last Post: 10-14-2009, 08:27 PM
