Quote Originally Posted by Zef_66 View Post
But what is the reason for putting in a colder t-stat. Everyone seems to do, but do they know why?
Why you say?
Usually the reason is combat knock. A hot engine will knock sooner than a cool one. So people will mod up and pulley up, get KR, and instead of demodding or tuning the KR out, they throw in a cooler t-stat.
While you particially answered your own question...there is more too it. Tossing in a colder T-Stat without tuning the car for it will do nothing but hinder performance and MPG's and put more of a premature wear on internal parts when not warmed up. The reason to run a cooler t-stat is also for the sake of...and the reason I do it...since the motor is running a little cooler (and like 15-20* difference is going to destroy your motor anywho...lol hardly) your not getting all those parts that like to break, rot, and fail due to heat...example, coolant elbows, LIM gaskets, Upper Intake Manifolds (97-03 cars), vacuum lines, rubber "T" and "L" fittings...and other misc. electrical things.
I firmly believe that your car will run better properly modded with no knock on a 195 t-stat than trying to run higher timing or more boost and a 180/160 t-stat.
And what is the firm beliefs on that? How else would you cool the motor itself down? Stock Thermostats are for stock cars. No mods...no intentions of going fast. If you see it a different way, I'm more than open to listen to ideas.
