Thread: Need help....sputtering bad
Results 1 to 20 of 23
  1. #1 Need help....sputtering bad
    Apr 2011
    central jersey
    Well I searched the forums for this problem first but have found no difinitive answer so hopefully someone can help......1999 gtp, borla cat back, modded dp, 3.4, custom air intake, 140k. Checked the plugs and they were v-grooves gapped at .050 and badly worn. Decided to change plugs and wires....replaced with autolite 606 and msd 8.8s. Ran great for about a week then started sputtering bad under load....as soon as boost gets near 5psi or over 1/3 throttle. Pulled a 301 code so decided to change cyl1 plug again just in case....changed plug and wire again. Still same prob so replaced coil w oem style.....still same issue.......sumone please help.....i love this car but my mechanic dosn't even know where to go now
  2. #2 Re: Need help....sputtering bad
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Check coils? Try swap one to the other and see if the misfire changes cylinders.
  3. #3 Re: Need help....sputtering bad
    St. Louis
    Per the "Safely Modding your 3800 powered car" thread...
    you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler
    AC Delco Factory Replacements: Stock
    Autolite 606: Stock
    Autolite 605: 1 Heat Range Cooler
    NGK TR55: 1 Heat Range Cooler
    Autolite 104: 2 Heat Ranges Cooler
    NGK TR6: 2 Heat Ranges Cooler
    Autolite 103: 3 Heat Rangles Cooler
    6) Exhaust - Here is where a lot of misconception tends to occur. Many people think that when someone says exhaust work that they can run 3” straight pipe from the cat back and drop to a 3.4” pulley and think that they have done enough exhaust work. Hardly. The cat back is the least of your worries as is flows good enough and has been dyno tested to not show signs of flow issues until 350+WHP, which is around 400hp at the crank.
    Other than your Borla catback and "modded dp", what have you done to actually increase the flow (ie- are you running stock exhaust manifolds?). Hopefully this is just a bad coil or injector. Is it misfiring on this cylinder only, or multiple ones?
  4. #4 Re: Need help....sputtering bad
    PA
    Was the plug smashed when you replaced it?
    2001 GSE
  5. #5 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    Coils were swapped....always stayed cyl1 misfire. Running stock manifolds and stock cat..... Plugd were not smashed when replaced, the car actually ran very well with the worn plugs and old wires, never had an issue until 5 days after plugd and wires were changed
    Little extra info.......
    Gapped new 606s at .060
    Car runs very consistent 180 degrees
    Vaccuum is 20in at idle in park, 18 in at idle in gear
    And again....car ran perfect on old plugd and wires but the were visually worn and old that's y I replaced them
  6. #6 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    Ok so I read the 'safely mod' section....it says I should use tr55 or 104......im a lil confused tho, a cooler plug =hotter spark? Just tryin to find a definite answer before I change plugs again.....i read multiple posts but can't find an exact answer
  7. #7 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    I kinda don't understand the plug thing.....cooler plug equals hotter spark??? According to the thread I should b running tr55 or 104 both of which are cooler plugs, but I want hotter spark??? Confused.....and the copper, platinum, iridium thing is confusing too.....i put 606 double platinums in and I think that's where my problem lies
  8. #8 Re: Need help....sputtering bad
    PA
    606s aren't bad. But you can run a cooler plug to help fight KR, which is an enemy for our cars. But no, cooler plugs do not have a hotter spark. They have a cooler spark. Same idea of running a cooler t-stat. To help prevent predetermination due to excessive heat.
    2001 GSE
  9. #9 Re: Need help....sputtering bad
    Kansas
    Quote Originally Posted by Zef_66 View Post
    606s aren't bad. But you can run a cooler plug to help fight KR, which is an enemy for our cars. But no, cooler plugs do not have a hotter spark. They have a cooler spark. Same idea of running a cooler t-stat. To help prevent predetonation due to excessive heat.
    Fixed. But yeah... that is why they call it dropping a heat range down. The blower increases the IAT tremendously and in turn, running a colder range spark plug to combat predetonation. Have you been constantly scanning your KR?
  10. #10 Re: Need help....sputtering bad
    Did you gap the new plugs?
    If the old were at .050" and worn, then that suggests they had started out smaller.. odd...but possible.
    Also if your misfire doesn't go away and you check spark at the plug..then it's a possible ICM. I have seen one or two not fire the second plug at the correct time. Really goofy when that happens.
  11. #11 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    I don't have anything to scan kr with....i take it to my buddy to check ses light. I'm going to try running the al104 plugs like the mods thread says and see if that helps.....they are only a few bucks ea
  12. #12 Re: Need help....sputtering bad
    You do not need 104's, they are too cold.
  13. #13 Re: Need help....sputtering bad
    PA
    And not going to do a thing for misfires.
    As I said, the only reason to run a colder plug is if you are getting KR.
    2001 GSE
  14. #14 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    I kinda dont know wat else to do....car ran great on the v-grooves I took out but the were worn to the point that the groove was almost gone......several people on this board say not to use platinums.....maybe switch to copper 606s?? Or should I swap out the icm
  15. #15 Re: Need help....sputtering bad
    PA
    Quote Originally Posted by Drw7475 View Post
    Your sputtering/misfire is not coming from the brand or type of spark plug.
    You have another issue causing the sputtering/misfire.
    2001 GSE
  16. #16 Re: Need help....sputtering bad
    I live here. TLSheff's Avatar
    ...1999 gtp, borla cat back, modded dp, 3.4, custom air intake, 140k...
    So youve replaced multiple times the plugs, wires, and coils. but it keeps being on cyl #1... I hate to be the bearer of possibly bad news but it sounds to me like you have a piston problem. Chipped pistons arise from pulleying down before your really ready to. You don't have headers, the exhaust isn't really helping because the restriction is still in the stock manifolds, yet your cramming excessive air into your engine.
    Do you have any knocking noise at idle or when you rev it up?
    Does it idle rough or funny?
    Is it JUST under load that you have any problems at all?
    video even?
    I agree with Zef, you have another problem...
  17. #17 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    I bought the car with the mods it has on it.....put 20k on it without one bit of trouble....idle is smooth....acceleration with no heavy load is smooth......no knocks or pings ..... Only happens when under heavy load and only happened about 100 miles after changing plugs and
  18. #18 Re: Need help....sputtering bad
    hrmmm... does it do it when the engine is cold? Ive seen the ignition module mess up and it stop sparking on the coils after it gets hot. Poor placement on GMs part
  19. #19 Re: Need help....sputtering bad
    Apr 2011
    central jersey
    Cold or hot....not intermittent....constant problem thru any and all variables
  20. #20 Re: Need help....sputtering bad
    Could it possibly be a vacuum leak? Sputtering only under load could also be sputtering under boost.
  1. Sputtering Problem...?
    By ray4was in forum General Tech Discussion
    Last Post: 05-02-2011, 09:41 PM
  2. sputtering under load
    By Jay7199 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2011, 01:44 PM
  3. gtp sputtering
    By ecflattracker in forum General Tech Discussion
    Last Post: 03-12-2010, 11:15 AM
  4. sputtering
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 02:25 AM
  5. help. car sputtering at wot.
    By 1gtp99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 05:15 PM
