Thread: Engine light flashing never seen that before?
Results 21 to 40 of 46
  1. #21 Re: Engine light flashing never seen that before?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Quote Originally Posted by torq455 View Post
    195 is better.
    Thanks dude
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #22 Re: Engine light flashing never seen that before?
    Charles City, IA
    You can go till the manifold is damn near in the radiator fan.
    SMGPFC Two Nipple General
  3. #23 Re: Engine light flashing never seen that before?
    Marysville WA
    Quote Originally Posted by TheOtherNick View Post
    Good too know ill let ya know if the new Plugs and wires cancel out my check engine or if im gonna have to pry open the walet tomorrow!
  4. #24 Re: Engine light flashing never seen that before?
    Quote Originally Posted by h0wl0ngcanitbe View Post
    But once I pulled the second bone out the engine rocked into the fire wall itself I just dont want to over do it and break anything.
    were you parked on a slight incline? if so set the e brake, and put the car in neutral, and then back into park, with the e brake still on. that should keep it from pulling like that on you.
  5. #25 Re: Engine light flashing never seen that before?
    Marysville WA
    Great news guys shes good as new! The issue was one of the front three spark plugs I was able to replace a few months ago but not the back cause I couldnt figure it out had a faulty plug wire attached to it, due to the fact that I couldnt replace the back set and put that off for another time I didnt want to replace the plug wires until I could get to the back plugs. And ultimately the problem was when I pulled the plug wires off the casing inside came loose.
    Lesson learned do it all or dont do it. Thanks for the help guys if any of you are in the Seattle area ill buy ya a beer!
  6. #26 Re: Engine light flashing never seen that before?
    Topeka, KS
  7. #27 Re: Engine light flashing never seen that before?
    There goes the chances of it being some cool new thing that we've never seen before.
    On to the beers!
  8. #28 Re: Engine light flashing never seen that before?
    Marysville WA
    On to the beers!
    Heh well for the sake of me and Lil Blacky im glad it was the most simple thing ever but seriously. Im not sure if im just being a tard??? But changing all 6 was a mother f#ck!ng b!tch.
    Even with the engine cranked out like 4-5 inches which im still blown away by that we can do that with our engines opens up a whole new world of maintenance for me!
  9. #29 Re: Engine light flashing never seen that before?
    PA
    Changing plugs is easy compared to some other things on these cars.
    2001 GSE
  10. #30 Re: Engine light flashing never seen that before?
    i had mine done in 30 minutes or less my first time out, wasn't that bad. and im a big ol goon.
  11. #31 Re: Engine light flashing never seen that before?
    utah
    You can make the front exhaust manifold hit the fan shrouds if u want. But you can asllo get to the rear plugs without rocking it at all. Give it a shot
  12. #32 Re: Engine light flashing never seen that before?
    I live here. TLSheff's Avatar
    You've never had the pleasure of working on a LS1 have you?
    Glad you found the easy way to do things, makes it much more fun vs being a pain in the ars and leaving you wanting to shoot yourself in the face.
  13. #33 Re: Engine light flashing never seen that before?
    Marysville WA
    Heh well Im just used to workin on a big K5 that I could literally sit up in and jump into the engine compartment! Those were the days!!!!
  14. #34 Re: Engine light flashing never seen that before?
    GT Level Member RegalGS98s's Avatar
    NJ
    Guess you haven't worked on the Ford Triton V8 or Nissan engines either have you. These engines are simple compared to others out there.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  15. #35 Re: Engine light flashing never seen that before?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    195 is better.
    Ahhh yes, mis-information at it's best........................
    That's the gpf.com way though, "it works for me, so its obviously the way everyone should do it"
    For all your 3800 needs:
  16. #36 Re: Engine light flashing never seen that before?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Not if it's stock or lightly modded.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  17. #37 Re: Engine light flashing never seen that before?
    Quote Originally Posted by copgtp View Post
    I look at it dependant on your current location. Here in Oklahoma it has been over 100* for 14 days straight. You need a 180* just to keep your engine cool, unless your on the highway solid.
    I do city driving in the heat of the day, I like my engine to be cooler. Now in NY and NE like you guys are, its debatable during summer and winter you understandably want a 195* if your stock.
  18. #38 Re: Engine light flashing never seen that before?
    While I agree...195's suck...people can't seem to grasp the concept that these motors run on average 10-20 degrees hotter than the opening degree of the thermostat. So your "195 is better" ISN'T correct...because techinically...especially if your not tuned and still have dexsludge sloshing around in the radiator...your saying 225 is better. I'd recommend a tune before a colder tstat since tossing a colder tstat in the car really does nothing but hinder mpgs until you lower the fan turn on point with a tune. Also...cop...like I said before...you don't like this site...easy. Don't post. I like the fact you give opinions but other forums are no better or worse. Thanks.
  19. #39 Re: Engine light flashing never seen that before?
    ya know, this thermostat temp thing makes no sence to me, the temp on the t-stat only reflects what temp it will open up, your car will still run just as hot as it always does with out one or with what ever temp you put in it, so if you put in a 160 you will have a flowing t-stat at 160 deg, vs 195 and the cars temp will still rise to what ever it runs at. it wont run any cooler in the long run.
    or am i missing something?
  20. #40 Re: Engine light flashing never seen that before?
    No, your not missing anything.
    The point was made that running anything colder than a 195* TStat was stupid...no matter your mods or tune. I disagreed.
    Old motor, old technology...they like to run cold.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Flashing check engine light!!
    By JOGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2010, 08:55 AM
  3. Flashing security light??
    By 91z in forum General Tech Discussion
    Last Post: 03-03-2010, 03:22 PM
  4. check engine light flashing help
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:09 PM
  5. Security Light Flashing
    By 01GPSE in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2009, 11:58 AM
