Thread: Engine light flashing never seen that before?
Results 21 to 40 of 46
Threaded View
  1. #1 Engine light flashing never seen that before?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So my 97 GTP was accelerating up a hill at about 50 and then I was getting a light shudder or maybe more like an engine gurgle. It was anything too bad and I wouldnt have been too bothered by it but the check engine light started blinking as it was happening and I have never seen that?
    So heres what im thinking? Maybe a heat issue? My heat gauge will creep up too 210 pretty quickly and will drop when the engine is not under load. And I was smelling a light burning smell after the hill climb.
    I have recently replaced the Idle Air Control Valve, and the MAF, did and oil change. I have not replaced the coolant or the Tran fluid and it just hit 140k. I havent replaced the thermostat which I will do probably in a the next week or so.
    Any thoughts before I take her into the shop? As I drove her around some more the gurgle only occurred at high speed and under load while going up a hill. As always the help is always appreciated.
    Edit: Is this a good work up of how to replace a thermostat?
    http://www.ehow.com/how_4590724_chan...rand-prix.html
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Flashing check engine light!!
    By JOGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2010, 08:55 AM
  3. Flashing security light??
    By 91z in forum General Tech Discussion
    Last Post: 03-03-2010, 03:22 PM
  4. check engine light flashing help
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:09 PM
  5. Security Light Flashing
    By 01GPSE in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2009, 11:58 AM
