Thread: Engine light flashing never seen that before?
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 Engine light flashing never seen that before?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So my 97 GTP was accelerating up a hill at about 50 and then I was getting a light shudder or maybe more like an engine gurgle. It was anything too bad and I wouldnt have been too bothered by it but the check engine light started blinking as it was happening and I have never seen that?
    So heres what im thinking? Maybe a heat issue? My heat gauge will creep up too 210 pretty quickly and will drop when the engine is not under load. And I was smelling a light burning smell after the hill climb.
    I have recently replaced the Idle Air Control Valve, and the MAF, did and oil change. I have not replaced the coolant or the Tran fluid and it just hit 140k. I havent replaced the thermostat which I will do probably in a the next week or so.
    Any thoughts before I take her into the shop? As I drove her around some more the gurgle only occurred at high speed and under load while going up a hill. As always the help is always appreciated.
    Edit: Is this a good work up of how to replace a thermostat?
    http://www.ehow.com/how_4590724_chan...rand-prix.html
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Engine light flashing never seen that before?
    utah
    when the light flashes its in a stop right now and im mean right now mode. dont drive it no mores til you figure it out
  3. #3 Re: Engine light flashing never seen that before?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Replace spark plugs and wires. It's a multiple cylinder misfire.
  4. #4 Re: Engine light flashing never seen that before?
    Jacksonville
    Specifically it means that your catalytic converter is overheating. If you drive like that for any length of time it will melt internally.
  5. #5 Re: Engine light flashing never seen that before?
    MO
    My blazer did it every time I drove. It ran on 5 cylinders.
    <brandonl2000> LMAO D!!
  6. #6 Re: Engine light flashing never seen that before?
    Portland Oregon
    Quote Originally Posted by scootcoupe91 View Post
    Huh!?
    Flashing check engine light is a misfire
  7. #7 Re: Engine light flashing never seen that before?
    Delaware, OH
    Quote Originally Posted by OH4CompG View Post
    Huh!?
    What he should have said is it's a "catalytic converter" damaging misfire. But as stated get it fixed. If it's enough to damage the cat, it's enough to trash the engine.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  8. #8 Re: Engine light flashing never seen that before?
    Marysville WA
    Ok thanks for the input, im gonna take her into the shop tomorrow, but before i get my ass handed to me by the dealership what should I ask to be done?
    Obviously diagnostics, but should I just go in their and be like its missfireing and I need new plugs and wires? Check my cat? I just dont want to get caught off guard and have them take me for a ride.
    Thanks again for all your help guys as always you guys rock!
    Edit: Also what is better a 180* or 160* thermostat?
  9. #9 Re: Engine light flashing never seen that before?
    Akron Ohio
  10. #10 Re: Engine light flashing never seen that before?
    Topeka, KS
    I've had this happen your car probably ate a spark plug. Check all your plugs or just replace them all. Same goes with the wires.
    That whole catalytic converter convo above is a bunch of BS!
  11. #11 Re: Engine light flashing never seen that before?
    Marysville WA
    Ok cool im doing that today, should I go OEM plugs or is investing in the pricier plugs something you guys would do?
  12. #12 Re: Engine light flashing never seen that before?
    just pick up some stock replacements wires, they work just fine.
  13. #13 Re: Engine light flashing never seen that before?
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Quote Originally Posted by rynoman03 View Post
    Not exactly misfires have a very big potential to cause over heating in the Cats. As the chemical reaction takes place in the cat it actually gets warmer than the exahust flow itself. Add that with any unburnt gas making its way into the cat and it can actually ignite in the cat itself causing the cermaic to melt
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  14. #14 Re: Engine light flashing never seen that before?
    PA
    If you are going to take it somewhere to get the work done, ask to see the plugs afterwards. If one or more than one is smashed, you have bigger issues to worry about. So ask to see the old parts, and make sure you tell them before hand so they don't throw them out in the process.
    2001 GSE
  15. #15 Re: Engine light flashing never seen that before?
    Jul 2011
    B-Town, PA
    it's low on blinker fluid. you might want to check the muffler bearings too. they are directly related.
  16. #16 Re: Engine light flashing never seen that before?
    Marysville WA
    Quote Originally Posted by Zef_66 View Post
    Im pullin the plugs myself this evening so Ill let ya know, If it is as you say it may be whats the full extent of the damage?
  17. #17 Re: Engine light flashing never seen that before?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Quote Originally Posted by h0wl0ngcanitbe View Post
    195 is better.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  18. #18 Re: Engine light flashing never seen that before?
    Could it be an injector?
  19. #19 Re: Engine light flashing never seen that before?
    Charles City, IA
    Flashing does means there is harm being done to the cat, everyone that says that is wrong is talking out their ass. Most of the time it is a missfire and can be fix by doing plugs in wires.
    SMGPFC Two Nipple General
  20. #20 Re: Engine light flashing never seen that before?
    Marysville WA
    When I am ratcheting out the engine after unhooking the dog bones how much should the engine ratchet out? Its just kinda freaking me out cause with just to dog bones out it seems like the motor should stay put. But once I pulled the second bone out the engine rocked into the fire wall itself I just dont want to over do it and break anything.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Flashing check engine light!!
    By JOGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2010, 08:55 AM
  3. Flashing security light??
    By 91z in forum General Tech Discussion
    Last Post: 03-03-2010, 03:22 PM
  4. check engine light flashing help
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:09 PM
  5. Security Light Flashing
    By 01GPSE in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2009, 11:58 AM
